Konica Minolta Bizhub C550 Logo
Anonymous Posted on Jun 10, 2013
Code 0204 shown, - Konica Minolta Bizhub C550
Anonymous
Level 1:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Contributor 45 Answers
  • Posted on Aug 30, 2013
Anonymous
Contributor
Level 1:
Filmmaker:
New Friend:
Answers
45
Questions
0
Helped
11585
Points
46
My machine problam code c-0204
what model machine?????????????????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I need for remote code for philips tv
PHILIPS:- 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
PHILIPS-MAGNAVOX :- 0062 0204 0207 0183 0226 0288
Philips universal ir codes
Universal remote codes for Philips are: 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141 For Philips Magnavox are: 0062 0204 0207 0183 0226 0288
Need code to program tv have universal roamoat
Try these codes.
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141 0062 0204 0207 0183 0226 0288
1helpful
Need codes for phillips tv
Hello
Three digit universal remote code for Philips TV are:
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit universal remote codes for Philips Magnavox are:
183/ 184/ 208/ 213
Four digit universal remote codes for Philips TV are:
Four digit universal remote codes for Philips Magnavox are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
I can't find the code I need to program my universal remote to my television.
Hello
Three digit universal remote code for philips are:-
Four digit universal remote codes for philips are:-
Four digit universal remote code for Philips Magnavox are:-
Proceedings:
NB: Switch OFF and ON your TV with its FRONT PANEL POWER ON/OFF SWITCH each time before trying an other code.
Direct Code Entry
OK.
I cannot find the code for my magnavox tv. can you send me the possible remote control codes?
Hello
Three digit universal remote codes for Magnavox are:-
183/ 184/ 208/ 213
Four digit universal remote code for Magnavox are:-
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Four digit universal remote code for Philips are:-
Direct Code Entry
OK.
1helpful
Got error C-0204 Don't know what that means.
this code means paper tray 2 is not lifting the paper up to the feed rollers.pull the paper out of the tray and make sure it is not folded up the side of the stack if it looks ok then you may have a failed lift motor or bent lift motor bracket
Have a GE RM24930. Lost manual. Need to program. don't have code for Phillips tv
Here are the 3 & 4 digit codes Philips
Philips-Magnavox
New 3
003, 004, 006, 008, 062, 068, 069, 074, 075, 076, 086, 087, 089, 133, 141, 163, 183, 184, 189, 204, 205, 206, 207, 208, 212, 213, 288
Old 3
003, 004, 008, 012, 019, 046, 047, 062, 068, 069, 074, 075, 076, 086, 087, 088, 089
8helpful
2answers
Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It happens when You put to much paper od while moving (for example). Solution: take out the paper tray 1 and 2, remove the paper from the space behind the trays.
Pixel
www.mojito-networks.com
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
