Samsung SGH-E900 Cellular Phone Logo
Anonymous Posted on Mar 22, 2009
HOW DO I GET MY SAMSUNG SGH-E900 OUT OF PREDICTIVE
HOW DO I GET MY SAMSUNG SGH-E900 CELL PHONE OUT OF PREDICTIVE TEXT, PLEASE
TONY
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
193
Points
Problem solved, go into messages create a new text message then click on options run down the menu to input method and click on Ab, now do you send me $5-99.
3helpful
Does the samsung e250 moble phone have predictive text
Yes.
All Samsungs have predictive text. It's t9 and will be found in message settings.
1helpful
How to set a samsung e900 to predictive text
applications menu !! predictive text to ON..
1helpful
Can't undo predictive text
mesages and long press # as to change the pred. text please also look at your right hand corner of your cell you will see abc_ dont stop till you se abc with no line following text
When typing out text message on my SGH-U600 when i get to the 3rd word it freezes and resets with the please wait command, then reboots itself, Im lost :(
hi had same problem, one solution is to take off the predictive text. go to write a text and b4 putting text on page, press options, no 7 input method and take off predictive text (Tab), you then have to text the other way which takes longer but at least can use phone, hope this helps
1helpful
2answers
Predictive Text?
Go into a message like you are typing a new one. On the left or right soft key, they should be "options" - select that. When in the options menu, look for "typing options", "writing options", or something related to the dictionary. It is in there that you should be able to turn the dictionary on or off, which enables or disables predictive text.
2answers
Samsung sgh-e900 txt language will not default to predictive
just go into your msg settings then change the predictive text to english standard.
1helpful
2answers
Predictive Text on Samsung D900
when you go to wright your text on the bottom right corner of the screen is the prompt for the type of text.
press the right control button and this will change.
you need T9text
3answers
Samsung E900
set all call barring and set call divert you can choose what you want!
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
