Question about Mitsubishi VS-50707 50" Rear Projection Television
TV turns off right away relay clicks
Folks, I have a Mitsubishi 50" VS-50707. Many a times it shuts down while viewing. Then it does not come on. When I attempt to turn it on either by remote or Power button on the panel, it comes on and shuts right back off and the relay clicks once. I put it into the diagnostic mode by pressing the input and menu button on the panel simultaneously and it gave me an error code of 24 - vertical delfection failure. I looked for dry solder on the board and resoldered the filter capcitors and the STRF6682 (IC 951)in the Power supply area. Is there a swithcing capacitor that I need to look for/replace? Where is the vertical IC located on this TV set and what numbers are they usually are. The TV does come back on after a hard reset (that is leaving the Power disconnected for more that 4 hours) then it functions for a few days probably a week and then it gets back into this mode. Any help from the TV Master Serviceman would very much be appreciated. Thanks!!!
    Genius:
  • 1,153 Answers
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Posted on Aug 27, 2007
SOURCE:
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
When I turn the tv on it turns off again right away
mine did the same thing then when we got it to stay on the picture was all messed up, and we;re hearing it will be quite a repair bill!
Nov 08, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Tracking on my tv Mitsubishi 50707 50in
i have the same tv cant fix the tracking .model 50707 mitsibishi
Dec 26, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707
Check the CRT socket of the tube that is arching. Could be a solder connection or shorted CRT. If you need further assistance let me know.
Feb 03, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
VS 50707 turns on, then off immediately
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsu. VS-50707 problems
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
50707 does not turn on, goes off immediately code 24, relay clicks
Aug 27, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
279 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
