Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
Posted on Aug 19, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carpet Height Adjusment
Sliding the height adjustment knob does not adjust the wheel height. From the underside, the tab, connected to the adjustable wheel plate, does not come in contact with the bottom of the sliding height adjuster. Help!
  • 5 more comments
  • fred s May 10, 2008
    Found a spring on the floor
    How do i put it back in the Hoover Bagless
    Wind Tunnel Self Propelled unit to regain
    control of the carpet height adjustment.
  • Anonymous Nov 12, 2008
    How do I fix it in stupid people terms
  • Anonymous Mar 16, 2014
    repair steering wheel height adjustment motor on 2009 nissan murano
    height adjustment knob does not work
  • Anonymous Mar 20, 2014
    height adjuster doesnt have a spring
  • Anonymous Mar 24, 2014
    panel underneath wont adjust to carpet length when adjust with knob. took odd back panel.. now what
    knob on top doesn't adjust underneath
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 01, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2874
Points
13
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Thatvacguy.com
Level 3:
  • Hoover Master 1,619 Answers
  • Posted on Nov 27, 2017
Thatvacguy.com
Hoover Master
Level 3:
Answers
1619
Questions
0
Helped
604941
Points
3345
The mechanism adjusts to the position when the handle is pulled back into vacuuming mode.
Is there height adjustment on Oreck xl vacuum mind is hard to push over carpet
There is no height adjustment, though you may want to check the wheels/rollers for hair and debris that may keep them from rolling well. If the wheels/rollers don't spin freely by hand, then you'll have to clean them.
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
1helpful
5answers
How do you fix height adjustment on Hoover vaccum?
This is a little joke that Hoover has played, and for some reason no one else has explained it. (One answer hints at it, but doesn't explain at all.) The height adjuster does NOT operate when the vacuum is in the upright & locked position. The tabs for the adjuster won't go into the holes above them until the vacuum is unlocked and at a slight angle. You can just install the height adjuster wheel assembly in the locked position, replace the lower cover, and voila! you will be able to adjust the height with the vacuum angled as it is for use. That's an hour of my life I won't get back!
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Height adjustment won't work on Hoover windtunnel
In my experience, Hoover height adjustment are "stops" rather than being attached to an axel. Look for something that rould resemble a set of circular steps somewhere in the path the axel would take as it goes up and down. It is usually on the underside from the knob that sets the height. Each 'step' represents a height with the shortest step being the lowest setting from a certain perspective.
On some Hoovers, therte is a ratchet petal on the right side. The ones I have seen are similar in operation to the above.
Let me know if this helps you.
A
Sep 21, 2009 • Vacuums
16helpful
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Can I fix height adjusment?
all i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
