Even with the VDC light on it shouldn't fishtail. Unless you have a lead foot or the tires are bald. Best to have the codes read. Could just be a bad wheel sensor.
Is your 2003 Subaru Outback automatic or manual transmission? If it is automatic, then your transmission sounds like it's malfunctioning into the reverse gear as it is not aligning properly. If it is manual, then your transmission sounds like it may have a bad clutch or bad reverse gear. Either solution is not cheap. Good luck.
The cruise control is automatically disabled whenever there is a problem that triggers the CEL. The flashing CC indicates that it is disabled. I'm not sure about the Stability Control light being on, but would think that if there was traction problem causing the Stability Control system to kick in, it would also turn off the CC -- the SC uses braking and engine throttle to stabilize the car so the CC has to be out of the loop.
If the CEL is still on, I'd have the codes read to see what triggered it. Usually, if a problem is not detected again for three consecutive driving cycles, the CEL will go out (although the code is stored for a longer time and can still be read). Read the codes yourself. 2005+ models display all the engine/transmission/abs/vdc codes on the dash.
Just perform this sequence within 10 seconds:
1. Turn key to ON position (just before START) 2. Turn headlights ON 3. Press Trip button 4 times 4. Turn headlights OFF 5. Press Trip button 4 times 6. Turn headlights ON 7. Press Trip button 4 times 8. Turn headlights OFF (optional)
Codes will display in the trip meter. You might have to press the Trip button to cycle between engine, transmission, and braking computers.
The abs/vdc codes, at least, should be saved forever unless a dealer clears them.
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can try
This problem could only be diagnosed is by downloading he fault codes from the transmission control module (TCM) you need to go to your Subaru dealer. I have access to the codes, but you need to know what codes are grenerated by your transmission.
(1) Disconnect connectors and terminal from starter. (2) Remove bolt which installs upper side of starter. (3) Remove nut which installs lower side of starter, and remove starter from transmission.
under dash connect together the 2 green multiplugs. The CEL light (Check Engine Light) will flash. Slow then fast. Count the slow flashes then the fast ones. I.E. code 21 will give 2 slow flashes then 1 fast = 21.
