HP Officejet 5610 All-In-One InkJet Printer Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to load 5x7 photo paper into hp photosmart D7460 ??
How to load 5x7 photo paper into hp photosmart D7460 i need o know how to load 4x6" hp photo paper in to my printer
Sudeep Chatterjee
Level 3:
  • HP Master 3,267 Answers
  • Posted on Mar 22, 2009
Sudeep Chatterjee
HP Master
Level 3:
Answers
3267
Questions
10
Helped
1159151
Points
10260
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
3answers
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Printing 4x6 photos with photosmart express - prints only 4x5 image on 4x6 paper
Hi
the photo printing settings will need to be changed on the PC to either the correct paper size or change the paper size to match the size of the print out
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Want to print 2 wallet size on 4x6 photo paper
under print options it will pop up a menu saying to "only show options compatible with my computer...." unclick that and it will allow you to select letter size paper again
I recently purchased a hp photosmart c7280 and want to know if i can print photos on 5x7 paper.
Hi - You can download the manual by clicking the link underlined in blue below:
c7280
See page 105:
So yes you can print 5x7 although 4x6 is recommended.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
8helpful
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
k24674
Grand Canyon Tech
Grand Canyon Tech
