Hello, I have sony vaio PCG-813M and when i start the laptop is ok until when the message welcome of microsoft showed each time then is a white screen and i can not have access on the control panel even in safe mode. how can i fix my laptop to work i only see a white screen nothing else
SOURCE: Computer keeps rebooting into safe mode
Try going to system tools, and select system restore .. If that does not work ,May be virus, may have full restore with formating the hard drive
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
SOURCE: white blank on acer 4315
It sounds like a Bios issue.
Go to http://support.acer-euro.com/drivers/notebook/as_4315.html
Download the latest Bios for the windows you are currently running and follow the Readme.txt and update the bios.
Hopefully this will fix the issue that is connect with the monitor and power setting in the bios.
Please Rate, Thanks.
SOURCE: PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
