Cars & Trucks Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the fuel pump in my 1985 Chevy S10 pickup, need all help. What is the procedures?
  • Anonymous Mar 14, 2014
    i need a diagram of a s10 fuel tank lines
  • Anonymous Mar 22, 2014
    changing a fuel pump
Ronnie Wilson
Level 3:
  • Master 1,596 Answers
  • Posted on Mar 22, 2009
Ronnie Wilson
Master
Level 3:
Answers
1596
Questions
Helped
881272
Points
5626
EXACT PROCEDURE ! Please Rate Me Fairly for this!! Thank you And Good Luck !!
ELECTRIC PUMP
REMOVAL
  1. Before servicing the fuel pump the fuel system pressure must be relieved. See: Fuel Pressure Release
  2. Disconnect the negative battery cable.
  3. Raise the car on a hoist.
  4. Remove the fuel tank. See Fuel Tank / Service and Repair.
  5. Remove the fuel tank sending unit and pump assembly by turning the cam lock ring counterclockwise. Lift assembly from the fuel tank.
  6. Pull the fuel pump up into the attaching hose while pulling outward away from the bottom support. Take care to prevent damage to the rubber insulator and strainer during removal. After the pump assembly is clear of the bottom support, pull the pump assembly out of the rubber connector for removal. NOTE: Inspect the fuel pump attaching hose for any signs of deterioration. Also check the rubber sound insulator at the bottom of the pump. Replace damaged or deteriorated parts.
INSTALLATION
  1. Push the fuel pump assembly into the attaching hose.
  2. Position the fuel tank sending unit and pump assembly into the fuel tank. Use a new "O" ring seal. NOTE: Care should be taken not to fold over or twist the strainer when installing the sending unit as this will restrict the flow of fuel. Also, verify that the strainer does not block the full travel of the float arm.
  3. Install cam lock over the assembly and lock by turning clockwise.
  4. Reinstall fuel tank.
MECHANICAL PUMP
REMOVAL and INSTALLATION
NOTE: To ease pump installation, rotate the camshaft so the camshaft eccentric is out of the way of the fuel pump rocker arm.
  1. Disconnect fuel lines from fuel pump.
  2. Remove fuel pump mounting bolts and the fuel pump.
  3. Remove all gasket material from the pump and block gasket surfaces. Apply sealer to both sides of new gasket.
  4. Position gasket on pump flange and hold pump in position against its mounting surface. Make sure rocker arm is riding on camshaft eccentric.
  5. Press pump tight against its mounting. Install retaining screws and tighten them alternately.
  6. Connect fuel lines. Then operate engine and check for leaks.
Does a 1985 chevy s10 have fuse for fuel pump or throttle body and were are they
Yes it does, and also a fuel pump relay controlled by the ECM or PCM.
Can be either problem.
I have a 1985 chevy s10 2.5 pickup that wont run right
Is the exhaust converter worn out,damaged & fails inspection?
eg: Exhaust Blocked
Timing Belt etc?
2answers
Where is the fuel pump reset button located in a chevy 1997 S10 pickup?
I DON'T KNOW OF ANY RESET BUTTON OR INERTIA SWITCH USED ON GM VEHICLES, USUALLY THEY DO HAVE FUEL PUMP RELAY AND RECIEVE BATTERY VOLTAGE FROM AN ECM FUSE
HOPE THIS HELPS
17helpful
5answers
Where is the oil sending unit located on a Chevy S10 Pickup.
MY S-10 IS LEAKING OIL. I WANT TO KNOW WHERE THE OIL SENDING UNIT IS.
Fuel issue 1985 pickup
did you change the pump with gauge cluster may have put bad pump in. some gauge clusters have built in pumps
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
