Helman Group RKP-630 Popcorn Maker Logo
Anonymous Posted on Jun 09, 2013
Instruction manual I don't have the manual and need to know how much oil and kernels to use
Tim Eischens
Level 2:
Champion:
  • Expert 252 Answers
  • Posted on Jun 10, 2013
Tim Eischens
Expert
Level 2:
Champion:
Answers
252
Questions
0
Helped
85238
Points
498
Http://www.nostalgiaelectrics.com/manuals/HKP200.pdf This model is very close to your model. They say it is a 2oz Kettle, so 1/4 cup kernels, and 1 tbls oil, 1/2 tsp popcorn salt.
1helpful
I don't know where to put the oil in my sewing machine
try go to the elna website and go to contact us, and contact elna
customer service and ask them about oiling the machine , it may
be a self oiling sewing machine.
tip
Sewing Machine Basics
Basic Problem Check: If your machine is not working correctly ALWAYS follow these steps first.
READ YOUR MANUAL!!!
1. Rethread top and botton threads. This can solve a lot of problems
2. Oil your machine per your mauals instructions. (I find I must oil my emboidery machine at the beginning of each project, but my basic machine can go up to 6 months between oiling depending upon use).
3. Clean you machine per manusal's instructions (don't forget to remove the throat plate and blow out aread below needle).
If these steps don't solve your problems you may need to take you machine to the shop and have them reset your machine to factory specs;.
on Mar 30, 2019 • Sewing Machines
I changed oil and message is still there
You must reset the oil change due message, refer to your owners manual for instructions on how to do this. If you don't have the owners manual you can download one free here
Can't find anything in the manual about oiling the sewing machine for my euro-pro 464xc
I have a Janome which does not need oiling. I can't explain this, but I've had the machine for 20 years and I clean it often, but no oiling. I found this statement below on another website:
"Many new modern machines don't need oiling. Indeed, oiling can wreck them by attracting lint and dirt to the places where it can damage the machine. Check the instruction manual that comes with the machine and follow the instructions carefully. If there are no oiling instructions in the manual then don't oil the machine -it doesn't need oil. If you think there's a mechanical issue that can be solved by lubrication then take the machine to a repair shop and have a pro look at it, it could be in a place where you can't get to without a pros help -or it could be something else entirely -like build up of dirt or lint." from: http://ca.answers.yahoo.com/question/index?qid=20110609192222AANV9DF
My Beaumark popcorn maker isn't working! I have the type that is a large domed electric pan, with a metal 'stick' that goes around to move the kernels (presumably to stop them from sticking?)....
your problem is in the instructions.. you need to make it a little hot, means run it on empty for a few min. stop the machine, and add 2 tablespoosn of veg. oil your fav. oil, not olive. add enough pop corn to fill the inner circle surface of the bottem plate, then run it again until the bowl is full.. maybe 5 min. You should have perfect bowl full of pop corn.
enjoy :-)
Sep 15, 2011 • Vacuums
Popcorn popper 50030178 I found this old popper like my nanny used to use. But I don't know how much popcorn or oil to use can you help me. I have the measuring cup lid all the parts with it.
What type of popper is it? The 50030178 model isn't one I'm familiar with.
For most of the small air poppers, such as the Presto Air poppers, fill the measuring cup lid with popcorn so that the popcorn is level with the top of the cup. Add this amount of popcorn to the popper. On those units, there is a fill line inside the popping chamber. Do not fill past the line. For these air poppers, if you want to have butter or margarine on the popcorn, add 3 tablespoons of the extra to the lid after you replace it on the popper.
For the Hamilton Beach Hot Oil Poppers, the manual for the 73300 is available here: http://www.hamiltonbeach.com/use-and-care/use-and-care.php . Fill in the type of device and then the model. The amount of oil and popcorn will depend on how much you want to make. For a single serving, you need 2 T (tablespoons) of kernels and 1 - 1 1/2 t (teaspoon) of oil. For enough popcorn for a family, you should use 1/2 cup of kernels and 1T of oil. http://useandcares.hamiltonbeach.com/files/840190701.pdf has a full chart of the amounts on page 6.
I hope this helps. Please add a comment with the brand of popper and I'll check for a specific chart for that unit.
(It's been a while since I used the air popper that I used to have.)
4helpful
I need to know how to replace the timing chain on a 2003 nissan altima 2.5 engine.
I really hope you know what you're getting into.....Big & detailed job. I went on and posted the instructions as far as removal and installation of the timing chain. There is a whole other section that you need as far as removing the oil pan and strainer but way to much to post on here at this point. Anyhow, it's a 2 piece oil pan and just to let you know alot of the parts like the timing chain cover, oil pan, the cover on the timing chain cover does not have gaskets and Nissan doesn't either. You have to use some RTV and don't go cheap, get the good stuff because all the work that is involved in this you don't want to have to repeat because of a leak. Also the oil pump is in the timing chain cover and Nissan has had some problems in the past with them. I would suggest going online and finding a new oil pump that comes pre-installed in a new timing chain cover. You can pick the whole assembly including the cover for about $150.00 and worth it. Wish you were here I have one ready to go. Anyhow, email me at [email protected] and what I can do is send you the engine management section of my service manual in a PDF so you have the info on the oil pan removal.....You need it. It will also have all the stuff I am posting below so you can make it big enough to see or even print out if need be and no there isn't a cost for it. I'm in a good mood....lol. I hope this helps. Here is the timing chain instructions for you.
Need instruction on a popcorm machine ccp509 and ccp-510. how much oil, butter, popcorn to you put in them. they came with no instruction.
CCP-509 User Manual
http://nostalgiaelectrics.com/manuals/ccp-509.pdf Instructions for use see Page 7
CCP-510 User Manual
http://nostalgiaelectrics.com/manuals/ccp-510.pdf Full instructions see Page 10
The instructions for the CCP-509 are not specific about the quantity of oil and kernels to use. The instructions for the CCP-510 are clearer, stating that for every measuring cup full of kernels ( 4 oz.) add 2 tablespoons of light vegetable oil.
I purchase this popcorn model number ofp901 i have no instructions it looks like the kpm508 and just need to know how much oil and popcorn
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
2helpful
2answers
Top Helman Group Kitchen Appliances - Others Experts
john h
Are you a Helman Group Kitchen Appliances - Other Expert? Answer questions, earn points and help others
