Lands Phones Logo
Anonymous Posted on Jun 08, 2013
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Trying to add old Vtech CS6209 handset to new CS6229-2 base. The handset display continuously displays "CONNECTING..." but will not connect to base. I no longer have the base that the CS6209 handset was registered to. Is there a way to reset the handset to the "Not Registered" state so that I can register it to the CS6229-2 base?
Art Cacella
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 186 Answers
  • Posted on May 12, 2016
Art Cacella
Expert
Level 2:
Passionate:
Answers
186
Questions
Helped
55436
Points
242
Yes. The'old' handset must be de-registered from its
original base and then registered to your base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !! --
5 Related Answers
Anonymous
  • Posted on Jun 13, 2012
SOURCE: I have purchased a SL82318
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
otacon
Damen Wong
  • 1950 Answers
  • Posted on Jan 01, 2008
SOURCE: Can not get the second handset to register to the base
After you got the no connection message after trying to register the second handset...did you try to register it again?
Anonymous
  • 3 Answers
  • Posted on Feb 14, 2008
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
lipitorus
  • Posted on Dec 03, 2008
SOURCE: My cordless phones need to be registered
Press menu button, the LED readout should say "press pager button and wait for beep".
I have a GE21900FE1 and it worked perfectly
Anonymous
  • Posted on Mar 12, 2009
SOURCE: How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Why do my VTech phones says outer range or no base on both of my phones
Out of range OR No power at base is shown in the handset ...
www.vtechphones.com/support/.../353
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
FAQs - VTech Communications
www.vtechphones.com/.../frequently-asked-...
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
VTech CS6429-4 DECT 6.0 Expandable Cordless Phone ...
Will the vtech interact with already an existing Uniden 5.8 ghz power max base unit and handset plus one additional handset and charger to give me four locations or just two more single handsets with...
Hi there, Your new phones will not interact with a base station from another brand of phones. If you want to use one base station, you can buy single phones of the same model and brand and those will interact with the original base station. Your new phones will not connect to the old base station Sorry, Alex
How do we add additional handsets to a vtech 6.0 phone?
search through the menu's for the base unit - and you should come across register handset - choose yes or accept ?
on the new handset you should also see register handset do the same select yes and the 2 should see eachother and link to one another
1helpful
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
3helpful
My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Vtech i5858
I had the same issue and by changing the battery my problem was definitively solved. I bought the battery on ebay for about 5$.
this is not mentionned on the vtech faq but it should
I hope this helps
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
