It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
When you ask for help, give make and model number. In this case, if display is a CRT type (cathode ray tube, not LCD), then a horizontal single line in the center of the screen indicates a lack of vertical deflection. If it is a vertical line in the center of the screen, it is a lack of horizontal deflection. Both problems can be caused by any number of components, all internal, and requires a technican to repair. Lowrance has a fixed fee system for their factory repairs. See their online info for support: http://www.lowrance.com/en/Support/Service-Information/Service-Rates/
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
I have the same problem on my unit and was told the same after I stayed on hold 38 minutes for tech support at lowrance. This is the second Lowrance that they would not fix and only offer a "discount" on a replacement. This company can KISS my behind. What a scam!!!
