You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
There are a number of possibilities, jammed gears caused by a disc or gears out of time, some have a very small loading belt located under the draw in most cases, excessive ware and tare on plastic gear linkage.
Hello, Try a soft reset, unplug the TV from the AC outlet then reconnect, then power the TV on. You should get some kind of a start up menu. If you don't then make sure you're DVD is operating normally there might be something wrong with the disc player and that is why it is reverting to disc pick up or disc load.
first you must check if your portable loads cd or mp3. If it loads cd or mp3 the defect is lens and this should be replace by an expert. If both cd,mp3 and dvd didn't load you check first the ribbon wire for signs of disconnection and foldings and then replace it. If still your portable didn't work the most probable defect is MPEG board.To distinguish if MPEG or lens defect in lens shows malfunction such as not reading dvd but reading mp3 or cd, unwanted stop of play even with a good dvd.
After all that fails, it's probably time to change the DVD drive inside
the player. Sometimes this is easy, sometimes not. :) I haven't been inside a 6300 but from looking at pictures, it's probably got a fully removable unit.
Of course, if you have a valid warranty, then when you're left with no
solutions that don't void the warranty, you have to decide whether to
try to pass it off to the warranty holder for repairs.
