Rosewill 19" 12MS DVI R911E LCD Monitor Logo
Posted on Jan 13, 2018
Mr Rosewill R911e will not display red. Blue and yellow display fine. No red pixels at all. Downloaded latest drivers, changes and tried all possible settings - resolution, hertz, NVIDIA control panel options, everything. It used to work fine, started flickering over the last several weeks, not no red.
  • diwansky Mar 22, 2009
    Forgot to mention... old HP Pavilion monitor displays fine.
Large yellow spots floating across TV screen
Adjusting the Color Temperature
Color temperature refers to how red (warm) or blue (cool) the color palette is. This control helps you to adjust the color settings on your TV. You can change the color settings by following these steps:
- Using the TV remote, select settings and look for a menu item labelled video or picture.
- Select Color Temperature. A slider should appear that allows you to slide between cool and warm colors. The colors might also be labelled red or blue.
- Slide the settings away from red/warm and towards blue/cool using the remote control. You can leave the slider at the point where the color is most pleasing to you.
I have an intermitent problem with my video display. More often than not, little red dots/pixels appear throught the screen, most obvious on photos or graphics. I upgraded from the basic 2gb ram to 4gb...
Hello. The red dots or pixels are due to your video card being overused and/or heating. Try updating to the latest drivers for your video card. You can find the latest drivers for your computer here: http://goo.gl/DJrDK
2answers
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
I have a samsung nc10, just downloaded blackberry desktop manager, tried syncronising my media and an error message came up stating "change the screen resolution to 1024 x 768 pixels or higher". This...
Every monitor and TFT's have maximum limit of changing resolutions, and if your laptop not support more than 1024 x 600 then it is not possible to change it for more high, it can be the problem of your video driver, first you should reduce your refresh rate to minimum, then see that it shows the resolution of above 1025x600 or not. If it is not shows then you have to download latest video driver for your laptop. Go to RUN type DXDIAG and click on Display tab you will see what your chipset is..then go to Intel.com then download a video driver of your required chipset then try. Good Luck
Hope the problem will solve..
7helpful
4answers
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
1helpful
2answers
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Hi receiving input not supported
This message shows that you are not setting the resolution correctly.
When you are in Windows, click on - Control panel - Display - Setting - Screen Resolution (set yo 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from [email protected].
Hope this will help you.
Ringo
Top Rosewill Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
