Question about Xterra Fitness Xterra FS220e Elliptical Trainer
Err After 6 minutes on the elliptical message "motor error" comes up this is an xterra el255
Getting err 1 message on diamondback 950e elliptical
I have never known elliptical audio cartridges give an error message - does this display upon your amplifier ?
Oct 10, 2017 | Cameras
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Esprit EL 255 Motor Error
http://www.spiritfitness.com/servicedocuments/pdfs/_0002_ESPRIT/_0002_ESPIRIT_02_Ellipticals/003_OwnersManuals/2010_ESPRIT/EL255_OwnersManual_255009.pdf
2009 manual so may be difficult to find a support telephone number that works for that model, but the web site above has a free manual. The main web site has a support email address, telephone number, and Store Locator for you to pursue an answer.
http://www.spiritfitness.com/residentialownersmanuals.html
sales@spiritfitness.com ' 870-935-1107 ' Store Locator
Mar 03, 2014 | Spirit Esprit EL255 Elliptical
I get a message of err 40, machine shuts down. you can flip the switch on and it goes away for a while, then eventually comes back
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Dec 17, 2010 | Precor EFX 546i Elliptical Version 4
Audio/CD Player
dear friend- the error code means the lazer is not reading your cd,if it is a pirate cd it might be the problem,or the lens must be cleaned.
Apr 17, 2009 | Hyundai Motor 2004 Sonata
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
Error message on elliptical machine
Try unplugging for 5 mins plug back in might reset .
Jan 23, 2018 | Kettler Mondeo Elliptical Trainer
M&S Systems MCD-6 6 Disc CD Changer display of "err 01" message
I do not know these units but I have worked on multiplay and many devices, the main reasons I found is either lubrication and or drive belts.
Over time belts stretch from decay as they age also silicon based grease I have found becomes divided between a liquid and paste with the liquid part making a puddle on a units lower area.
This causes things not to operat within a suitable time due to friction or lack of power from those belts which result in error numbers.
A good service is the only answer with a good service engineer who I am sure will enjoy cleaning out the residue slime, clean parts and relubricate. Sarcastic of me maybe but it was to make you aware that it may be costly due to time involved.
Hope this helps.....
Jun 02, 2017 | M&S Systems MCD-6 6-Disc CD Changer
Xterra Fitness Xterra FS220e Elliptical Trainer Logo
332 people viewed this question
Top Xterra Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
