My AEG Lavamat 74800 stops part way through the cycle and reports Error E50
someone suggest resetting it - but I don't know where to find the reset button. If the reset involves a combination of operations with the frontpanel controls, if anyone knows what they are could you let me know please.
Thanks - Phil Benton
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
I suggest you try this link. They will help you online.
https://www.justanswer.com/uk-appliance/...
SOURCE: error E50 how can i
Hi
Thanks for using FixYa. Error E50 indicates motor
fault, you’ll have to check the brushes and wiring of the motor and check if it
makes a hum sound, if it does and you can see that the motor is not working
then it is the motor that should be replaced. If everything else appears to be
working fine then it is the PCB that should be replaced. Please do accept the
solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
