I am unable to copy movies or any documents from a pen drive to my pc desktop.
SOURCE: Acer Aspire T180 PC Desktop
if you have windows 98 boot disk put that in, the firt thing you do is to go to f-disk and change the partions in it, then format c: drive. take out disk in A drive put in New windows XP CD and restart. the disk will run and install itself. and thats it. right now your partions are set to read only windows 95, 98, there are 2 options to choose from I belive the one you need is 32.
SOURCE: REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
SOURCE: unable to transfer files to sony 4gb pen drive
Restart your PC and try it again or try it on other PCs. If problem persists then pen drive is defective. Return to retailer and ask for a replacement.
SOURCE: I have a eMachines T3418 desktop, and like this
If you did a system recovery, it may have told you that it would save your data, but it wouldn't be in the recovery partition. That partition is meant for system files only and it isn't too large.
It could also have told you that your hard drive would be reformatted and the system returned to it's new condition. This means all data was wiped from the hard drive.
So--the answer is: It depends on what you agreed to when you did the system recovery.
