Question about Archos 504 500870 Digital Media Player
Archos 504 I have a new 504, which I hadn't used for about 2 weeks. When I went to re-use it, it wont hold a charge, and simply turns off. Does this mean that the battery is completly dead?
I had a similar problem remove the battery and push the gold coloured reset button. It worked on mine, You don't lose any info doing this. I got the advice from the Archos support phone number CC
Posted on Sep 17, 2007
I have had a similar problem with my Archos 504 80GB. In order to repair the problem I took off the battery for about 30min to an hour so it can clear its memory. After that try putting the battery back and see if it turns on and stays on.
Posted on Aug 21, 2007
SOURCE:
Archos 504 dysfunction
Did you try to reset the device? Turn off the Archos, remove the battery. Near the 2.5" hard disk you will see a small golden button. Press it with the tip of a pen during 10 seconds. Put the battery back and turn on the device. Maybe it helps.
Jun 25, 2010 | Archos 504 500870 Digital Media Player
My archos 504 will not charge the battery . how much is a new battery
You can get one in www.newmp3technology.com for 22€ aprox.They are Archos providers,and the large life of their batteries are well tested.
Feb 05, 2010 | Archos 504 500870 Digital Media Player
My archos 504 wont charge when i connect to my computer
The Archos need to be plugged into an "active" USB port, giving 5volts and no less than 500mA. Some old computers or laptops couldĀ“nt reach this performance.
Feb 02, 2010 | Archos 504 500870 Digital Media Player
Archos 504 wont turn on
Disconnect the battery for few seconds and replace back again, then turn on. I had the same problem and that was what I did.
Sep 17, 2009 | Archos 504 500870 Digital Media Player
My archos 5 wont switch on to the home page
You should perform this when it is on
problem solve #1
* Press the reset button on the buttom of the device using a papr clip. It should shut it off. then try to turn it on again.
try the next if the problem still exist.
Problem solve 2
* Download the latest frimware from Archos.com on to the desktop on your computer ( i recommend desktop because it will be easy to find) Then plug the device to a pc Using USB cable. turn the archos on by holding power switch and TV/LCD buttons at the same time until a white screen comes up. it should ask for Usb. if it does pick the ubs. if it does not give you a USB option but these "NO", "REPAIRE", "FORMAT" move the curser to repaire. do not pick the format which will delete all the contents and plugins you have on your device.
after repaire completes it should say done. do not press the done wait until you see the archos connection under My computer. it should normaly come up with name 504 or you will be able to see the archos icon. place the firmware in to the main drirector not under any folder. then press the ok button to confirm the "done" device will power off and start with a white screen again but this time it will update the firmware and restart do not unplug the Usb cable until the update completes. It should restart again and load the normal user interface. Your device should be fine and back to normal.
Jan 03, 2009 | Archos 504 500870 Digital Media Player
Archos 504 160gb wont start up. Tried new battery still didn't work, put my battery in another archos 504 this started up no problem. Asked for help from Archos - rubbish. Please help!!!
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
Dec 02, 2008 | Archos Audio Players & Recorders
504 recovery screen
hold the tv button slightly earlier than holding the power button, first tv then power (while still pressing the tv button). it should first boot up to a normal green ARCHOS screen, then it will enter the recovery mode.
Sep 08, 2008 | Archos 504 500870 Digital Media Player
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
Jul 21, 2008 | Archos 504 500870 Digital Media Player
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
Nov 16, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
302 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
