I try to install the Program DVD but il's seem to be impossible.
The message is :put CD in the Driver... but the CD is in...
I had been able to install the PrintMaster Scrapbook Creator and the Bonus CD.
So I need help before to the that in the garbage.
Thanks.
Are you using Windows 10? If so, this may be your problem:
http://support.encore.com/technicalsupport/kb.aspx?kb_id=2038&product_id=2644
If your OS isn't Windows 10 and this isn't the problem, please post again with your OS.
SOURCE: I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
SOURCE: Where can I acquire a manual for Printmaster
i couldnt locate one on the new but if you launch the program it will have a help feature under the list on the MENU bar on printmaster you might have to print it... or call Broderbund for a replacement ... you might even fine one on ebay ....
Testimonial: "Thank you for the info."
SOURCE: Is there an instruction manual for Printmaster Platinum 2.0
Is there any PDF documents on the CD-ROM?
Is there a "help" function within the software?
SOURCE: I have cracked my program disk for printmaster
you are gonna love this site. It is called www.emule.com you can down load anything, I mean anything for free, and your print master cd you should be able to get right away, see the way the site works is it grabs bits and pieces from owners arouond the world, so if you are looking for some high price software, you leave it running in the back grouund for as long as it takes, a day? 3 days? a couple hours, now this little old cd you need, you should be able to get it right away, also here is another idea, if the cd is cracked, but not cracked in half all the way, super glue it, but use very little as possible then clean cd to make sure there is no glue exposed on the cd surface, and it will work, let me know how this goes.
SOURCE: I am trying to install printmaster Platinum 18 on
"Error 1311" -Source file not found.
Maybe this workaround may help.
1. http://support.microsoft.com/kb/325076
2. http://www.ehow.com/how_5556804_fix-error.html
