I know that 95 durometer EVA is available from other sources like shoe findings suppliers. This is about 1/2" by 1" by 1.5" and if a mechanic was able, he could fix you up with that. If that is what you need, they could help you out without having to replace the whole assembly.
: I recommend getting ahigh chair for babies in this age. Boosters will not provide the body sidesupport a baby needs. When your baby is sitting and stable (when about 1.5-2Years, than it is safer to try a booster.
As a general rule, it is best to replace the caster as a complete assembly consisting of tire and wheel hub. Usually this is the only way to replace casters when the tire is molded on to the wheel hub. It is the best way to replace the caster since you get a tire, wheel hub and 2 new bearings.
With regard to the drive wheels on a manual wheelchair you can get just a new tire. With a plastic mag wheel and hand-rim you can sometimes get just a replacement snap-on tire to replace the existing.(Snaps on like a rubber band using tire irons). If the hand-rim, wheel, spokes, and bearings are worn or broken, you are usually better off replacing the wheel assembly. With power chairs, it is more cost effective to only replace the drive tires and use the existing wheel rims. Hope this helps.
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Liz First Did Medicare buy MIL's chair? If they did contact me @ [email protected] and I'll give you more info. Now after that long the tires get brittle and usually need replacement. You can contact the provider where MIL got her chair and have them get the caster wheels for the chair. Hope this helps
Wbritt You can call Pride Mobility @ 1-800-800-8586 select parts and order part # FRMASMB3772 make sure to ask if that is the correct part # for the rear caster assembly Hope this helps
I assume you are referring to the caster tire, not the drive tire. You will need to check to see if the rim is a split-rim or a solid rim. A split-rim will have 4 or more bolts holding the two halves of the rim together. If you have flat-free tires i.e., foam-filled solid tires, evidenced by the lack of a valve stem which is used to inflate non-flat-free tires (pneumatic), you would remove the wheel from the caster by rermoving the center bolt acting as the axle. Then remove the bolts holding the rims together. Reposition tire on top of one of the rim halves, then place the other rim half on top so that the bolt holes in the top one line up with the holes in the bottom one. You need to buy a couple of bolts that are about 3/4 in or more longer than the bolts that you removed, as you now must press the two halves back together and the stock bolts probably won't reach through. Put the two longer bolts in opposite of each other in two holes and tighten down. When the rims are pressed together, then put the stock bolts in, remove the two longer ones and replace with stock bolts. Place wheel back on the caster. If you have pneumatic tires (requiring air), make sure to always deflate the tire completely before attempting to loosen the bolts holding the rim-halves together. The same process is used for drive tire replacement. If the rims are not split rims, then it is easiest to buy an entire new wheel and tire as getting it back on is quite a chore requiring a press and lots of tequila! It's easy to break the rims. Good luck.
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can
re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
