I have a external harddrive that when you plug it into the playstation it won't read it. I have 2 ps3's and they both used to work but when I updated it now neither of them will pick it up. I have the folders marked properly by usually it would say USB device on the pull down and it doesn't.
SOURCE: ps3 system update data corrupted
Hook up the external to your USB port and copy everything over. I had to do that when I installed a larger hard drive in my PS3
SOURCE: At first the playstation 3 would not read PS3 game
Hi, it sounds like your laser either needs cleaning or is shot. First try cleaning the laser by blowing some canned air into it and see if that helps.It usually isn't the problem. If it dosen't then there is a very good chance your laser is broke and needs replaced. This is a very common problem with the PS3's. It starts by not reading certain discs then eventually it won't read anything at all. I would take it to a game repair shop and have the laser replaced. If you want to do it your self (its pretty simple really) it will save you some $$$ and you will have it back sooner. I will be more than happy to walk you through replacing the laser if you choose to do it yourself.
SOURCE: New HDD 250GB installed in PLaystation 3
Hi mate I read my nephew's booklet, apparently you have to go on the internet and download a program from the Sony website and write it on a cd, then you run the cd inside the ps3 and it should format the cd and load the system files on it.
Alternatively if you are not prepared to wait 20hrs for it to format, pop it into a computer with SATA compatibility and format it FAT32 (not NTFS your PS3 will not be able to access it), you will be able to save all your games and mp3 and videos on your new hardrive.
SOURCE: To make sub folders in a Picture file on a
There may be any Software that is causing conflict. In this case, you can try installing the Software on a Computer with a very few applications installed on it. Or, you can uninstall all the unnecessary applications from the Computer and then try installing it.
I think you need to group them by albums
on a picture hit triangle then choose discription and change the album to whatever foldername you want and then under the main "picture folder"
hit square and choose sort by album this will create sub folders with the album name as the folder name.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
is the scratchy sound coming from inside your lacie or outside ??
it might be a power problem trying to connect to your lacie but unable to find the device or a dirty hard drive the reader arm skipping across the platters you could give your lacie a firm tap on the side to free up the reader arm
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
