For about five wash cycles now, the bleach dispenser on this unit is not emptying. In other words, the same bleach has been sitting in the dispenser for a while.
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Bleach Dispenser is not emptying
