Battery exhausted message
no battery charged
The manual says:
Confirm all connections.
Off is selected for Charge by computer in the setup menu.
When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.
In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
