The camera was working and then when I tried to go on skype with video it indicates there is no webcam.
Update the webcam driver in your computer. You can get the crystal eye driver from the website of acer. But if you would like to cover all drivers in your computer then you can use RadarSync scan so that you will know which drivers are outdated. Keeping them updated would fix the issues.
David
SOURCE: to capture video acer aspire 6920 acer crystal eye webcam builti
you need to download a video capturing device
if your system did not come with one
the built in webcam is exactly that for messaging programs and taking snaps but they can be used for video and this is usually something you need to get on your own
debut is usually a pretty good site
please don't forget to rate me
SOURCE: Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model.
When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
SOURCE: Aspire 9920 Crystal eye webcam problem
Update the drivers (let me reveiw the specs i can get)
http://acer-crystal-eye-webcam.software.informer.com/
These are the latest i also recomend a virus scan just to be safe
Testimonial: "Driver succesfully installed, crystal eye webcam is working again. Thanks a lot for your help ! Greetings "
SOURCE: acer built in crystal eye
Try to roll back the driver in device manager. You can try uninstalling the usb root hub associated with that device.
SOURCE: I have acer aspire 5720z.
Check if you driver is correct, wether your operating system is 32 or 64 bit it should match the webcam driver.
