Question about Nintendo GameCube Console
Nintendo GameCube power loss after on for 20 mins
When playing the GameCube for about 10-20 minutes the system will shut off.
Mine did the same thing for a while, try cleaning off the screen on the left side of the console, worked for me. Good luck and Godspeed!
Posted on Mar 16, 2008
    Problem Solver:
  • 18 Answers
Does the gamecube have proper venelation? Did you try buying a cooling fan to see if that prolongs the gametime? To me, it sounds like it is overheating and shutting off before any real damage can be done. Try this and see if you get any results: Put your gamecube in middle of the room, to give it plenty of air and turn it on and see how long you can play it. If it doesn't shut off, the place where you usually have it probably doesn't have enough venelation to keep the cube cool. If that doesn't seem to do anything, check and make sure all the connections are snug (i.e. gamecube to power strip...etc.)
Posted on Aug 19, 2007
SOURCE:
Wii has no power!
Troubleshooting - Power
No Power
Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
If this fails, try resetting the AC adapter.
Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
Oct 02, 2012 | Nintendo Wii Console
Whenever I try to play my Super Smash Bros. Melee game with 2 players (me and my dad),It always automatic turn off. I tried every combination of black and white controller,but no working. WHY IS THIS...
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Feb 27, 2011 | Nintendo GameCube Console
My Nintendo Gamecube seems to reset by itself about every 30 minutes, can anybody help?
If the power shuts off during game play or resets after 30 minutes after the system is turned on then turns off and won't turn back on or the fan isn't working, the system needs to be repaired then. This problem that you have might be the fan thats causing this problem then.
Jan 08, 2011 | Nintendo GameCube Console
Turns off automaticly
  • Power Light Shuts Off
  • Sep 27, 2010 | Nintendo GameCube Console
    No power The light does not come on. The game does not turn. The fan does not blow.
    • No Power
      1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
      2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
      3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
      4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
      5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
      6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
      7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
        1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
        2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
        3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
          • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
          • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
      8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
    • Power Light Flashes
      If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
    Dec 21, 2009 | Nintendo GameCube Console
    Power button failure
  • Sep 11, 2008 | Nintendo GameCube Console
    My gamecube has problems with reading all my games
    did you check the back of all your discs for scratches thats the problem or gamcubes broken down if you try a new game and it does the exact same thing send your gamecube to nintendo for repair hope this helps.
    Dec 20, 2007 | Nintendo GameCube Console
    Fix gamecube
    check all your cables, i had the same problem and it ended up being a joystick with an exposed wire. i actually returned the first gamecube because of this but when the second one had the same problem i ended up searching on the net for answers. the gamecube shuts itself down as a safety feature so just double check all you cables, the problem joystick in my case was hardly noticeable so look closely, gluk!!
    Dec 13, 2007 | Nintendo GameCube Console
    Gamecube - blank screen, disc wont spin, power light and fan work.
    No Power
    Power Light Flashes
    Dec 07, 2007 | Nintendo GameCube Console
    Nintendo GameCube Console Logo
    102 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Ekse
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
