I have a Toshiba Regza model 46sv670u, bought it with no remote or manual. So I'm using the side panel because the universal remote doesn't work well with the TV for some reason. My picture is stuck in 4:3 format when the cable is on. But when I play a movie it goes into widescreen or fullscreen. I've tried every single picture setting. Turned off the auto aspect but under that it only says 4:3 stretch on or off and I've tried both. Any ideas?
Http://www.google.co.in/search?q=Toshiba+Regza+46sv670u&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8&redir_esc=&ei=rNSwUfnUFs2xrAfAwYHQDQ#rls=com.microsoft:en-US&sclient=psy-ab&q=Toshiba+Regza+46sv670u+user+manual+pdf&oq=Toshiba+Regza+46sv670u+user+manual+pdf&gs_l=serp.3...5207.8961.0.9373.16.16.0.0.0.0.291.3025.0j13j3.16.0...0.0.0..1c.1.16.psy-ab._CYzo16EX0g&pbx=1&bav=on.2,or.r_qf.&bvm=bv.47534661,d.bmk&fp=f937b014d7d58ef3&biw=1024&bih=653
Check this link to download the user manual. Check this link, if you wish to get more. http://electronicshelponline.blogspot.com/
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
SOURCE: I have a Toshiba regza LCD 32AV600 TV set. The
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
SOURCE: i just bought this tv
Tvs universal remotes u get what u get there alway somethings missing or funsctions improperly.That why u don't exspect perfection on those tvs univeral remotes,just the tv remote basic funsctions only all of the times.Try website like Remotes.com to buy the tv original remote.
