Is the serial number for a Stihl 021 saw, purchased in 1996, stamped on a metal plate under the muffler or is it in relief under the main casing of the body of the saw?
SOURCE: stihl 021 running poorly
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
