Nikon LS 2000 Film Scanner Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon scan was unable to find any active devices
Running xp on Sony Desktop, using scsi, nikon software is also installed (ver2.0.1),
when I open nikon software, it says "nikon scan was unable to find any active devices".
Unit is turned on. and shows in device manager.
Am I doing something wrong?
If scanner light has problem, can it be recognized?
I have tried booting computer first, then turning on scanner. and the other way around.
Help?
Brian Williams
Level 2:
Scholar:
  • Expert 48 Answers
  • Posted on Apr 04, 2009
Brian Williams
Expert
Level 2:
Scholar:
Answers
48
Questions
0
Helped
20315
Points
103
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
1 Related Answer
Brian Williams
  • 48 Answers
  • Posted on Mar 21, 2009
SOURCE: dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
1helpful
2answers
Using my Dimage Scan Dual 4 SW with Windows 7 gives me trouble. Have konica Minolta SW ver. 1.0.0 for windows XP. It works fine on the XP computer. But I have great difficulties loading the SW on
Have you right clicked on the .exe file of windows 7 executable for the Minolta scanner to select compatibility to switch it back to xp.Have you tried to use third party twain drivers for scan software such as silverfast or vuescan instead?
Problems with coolscan3 and AMD64 machine
hi, please find enclosed a link showing nikon scan compatibility with different operating systems if you are using xp 64 bit or 32bit the table is showing that your version of nikon scan is not compatible http://nikoneurope-en.custhelp.com/cgi-bin/nikoneurope_en.cfg/php/enduser/std_adp.php?p_faqid=7894&p_created=1068557916&p_sid=LeP*VyJi&p_accessibility=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAmcF9wcm9kcz0yNSwzMSZwX2NhdHM9MjQxLDE3OSZwX3B2PTIuMzEmcF9jdj0yLjE3OSZwX3BhZ2U9MQ**&p_li=&p_topview=1 hope this helps
Does not work with windows 7; cannot connect to scanner
You have to replace the original Konica Minolta driver with the custom one I have created below. Here are the detailed steps.
1) Install the Konica Minolta XP software in Vista/Win7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c:\newminolta\sonyscanners.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta XXXX (depending on model) and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c:\newminolta\sonyscanners.inf and click OK
14. Click Next. Windows should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
17. If you are trying to use a Minolta 5400 with firewire in Windows 7, you have to change your 1394 driver to the legacy windows 1394 driver in order for the scanner to detect. Google for instructions as it's too detailed to add in here.
18. The above driver should relink virtually all known Minolta scanners (USB/SCSI/Firewire) to the Windows TWAIN driver so it will work with the legacy Minolta software.
5helpful
2answers
Konica Minolta Dimage scan dual film scanner will not connect to windows 7
Copy this into a text file named "sonyscanners.inf" and then manually point to it as the correct driver in device manager for your scanner and it'll all work like magic again. Forget using a virtual machine...not needed. I use this for both the Dimage IV and 5400 Elite in Windows 7 64-Bit.
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
1helpful
Looking for driver for Minolta Scan Elite 5400 (not II) in wndows7
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
3helpful
Coolscan 3 and Windows XP
Try a good scanner program called vuescan. Much better than Nikon software. I have been using on XP for a long time and no problems
Dell laptop wont recognize ls2000 scanner
3helpful
2answers
Connection problem (error4 ) Minolta Dimage 5400
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
2answers
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Drivers for Nikon LS 1000
I believe that's a SCSI-interface scanner, making its setup more complicated than there's room for here. Here's what Nikon says about SCSI setups: <http://tinyurl.com/2wxp7p> and the Nikon software for the LS2000 and LS3000 (but maybe it'll work for the LS1000 too) is at <http://tinyurl.com/2qko5e>. There's a good set of detailed installation instructions under cineman's entry at <http://hardware.mcse.ms/archive47-2005-6-203500.html>. Good luck!
Lenny
Feb 11, 2008 • Photography
Top Nikon Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
