Question about HTC P3300 Smartphone
HTC Artemis (P3300) can't boot
Hi. I have HTC P3300 with Shell.5 by flecky Spanish Rom and when i flashed it worked for 2days and now i can't boot it. I tried to enter bootloader but i can't. I also tried both soft and hard reset but no change. :( It is stuck on boot screen. Can someone help me solve this problem? :( IPL 1.12.0001 SPL 1.11.cmon GSM 03.07.90 OS 3.13.0.0 Thanks...
4 Suggested Answers
SOURCE:
SOURCE: stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Posted on Mar 17, 2009
sardanadixit
  • 813 Answers
SOURCE: i flashed a cdma rom on a gsm htc diamond and now
In case it is not going into bootloader even, then it is bricked and you need to send it to HTC service center. There is nothing that can be done as the bootloader has been damaged.
Posted on Sep 29, 2009
  • 143 Answers
SOURCE: how i can change my phone langguage to english htc p3300
click start menu
click settings - bottom of start menu
click system - second menu
click picture of globe - regional settings
Posted on Mar 15, 2010
How to upgrade ROM version 3 07 707 01 for HTC P3300
here is ROM
http://rapidshare.com/files/42771542/P800w_SEA_ENG_WM6_Upgrade_20070713.rar
ALSO
http://wiki.xda-developers.com/index.php?pagename=Artemis_Upgrades
Mar 21, 2010 | HTC P3300 Smartphone
My HTC P3300 has died, does not want to turn on, and when it does, it freezes and stays the same until i remove the battery. It still charges the battery, but does not want to turn on. Please help
ok it could be one of two things so tru this first..
buy NEW battery..
charge while OFF!
LED goes off when fully charged.
if after this is does not work then add me to messenger and ill walk you through the steps to flash the rom on the device.
raving_nanza@hotmail.com
Feb 18, 2010 | HTC P3300 Smartphone
My htc p3300 wont turn on on the button.but when i hard reset it it comes on.but stays on htc screen
sounds like either the rom on the device is corrupt.. or simply you need a new battery..
try battery first.
buy NEW battery..
charge while OFF!
LED goes off when done..
if this does not work theni think you will need to flash the rom.
however..
first add me to msn messenger;   raving_nanza@hotmail.com
and i will be ale to assist you one on one from there..
Feb 15, 2010 | HTC P3300 Smartphone
How can i connect HTC P3300 to pc with bluetooth
It's as simple as that.
1. Enable bluetooth on your HTC phone.
2. Tap 'Start' > 'Internet sharing'.
3. From the 'PC connection' drop-down list, seletec 'Bluetooth PAN.'
4. Tap 'Connect'.
5. Enable bluetooth on your computer/laptop.
6. Go to 'Conenction Manager'.
7. Select 'Conenct via bluetooth'.
Both devices will be in sync now enabling you transfer data.
Oct 18, 2009 | HTC P3300 Smartphone
HTC P3300 Ringtone & WMP not working
sounds like a hardware problem.
try opening the phone up and having a look at the speaker connection.
maybe get a new speaker for it if problem persists.
Jul 20, 2009 | HTC P3300 Smartphone
HTC P3300, Windows Media player not opening.
try hard reset.
sounds like software issue..
if hard reset dont work try doing a rom update.
Jun 11, 2009 | HTC P3300 Smartphone
Htc p3300 problem
I have the same problem with my p3300, i tried to flash a new rom from xda developers, but nothing..
i tried to change the battery, again the same problem...
could somone help us!?
Apr 19, 2008 | HTC P3300 Smartphone
Please please help me
you need to flash the device - the rom is corrupt by the sounds of it..
add me to msn messenger and ill walk you through the flash process..
Feb 27, 2008 | HTC P3300 Smartphone
HTC P3301 LANGUAGE PROBLEM
You have to CID Unlock your phone forst before you put a new ROM file to it.
CID= Country ID locked, without unlocking you cannot use a different language , if it's locked you can only have portuguese inside and not english.
After CID Unlock use the desired ROM file which is the actuall software update with the language files.
You can find help and software to do it here: www.xda-developers.com on the forum.
Jan 05, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
186 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
