Oven wont start. Door locks, I have to turn off power to unlock it. When it does unlock the door wont close properly in order to heat.
SOURCE: Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
SOURCE: GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
SOURCE: Microwave oven comes on when
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can order Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
SOURCE: REPLACING DOOR HANDLE
You have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
SOURCE: Have a Sharp R930AK microwave.
You probably have a problem with the bottom door switch, or its mount may be loose or damaged.
We have
the service / repair manual for this model and have uploaded
it to our
site here for free download to help you.
It will
give you safety info, step by step help in disassembly, troubleshooting
tips, and part numbers.
You can order parts from
Encompass here
or you can call them toll-free at
866-779-5835.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
Even though a door
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
There are
plastic mounts inside the microwave which hold the door switches and
The screws on these
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
If you still have questions, please reply back, otherwise...
We're
