Oven will make a beep when buttons are pushed but oven acts like it is froze up when you close door.clock window reads F6 instead of time.is it worth fixing or should i trash it.
F6 means a problem in the control circuit board. Try unplugging the microwave with the door open, then plug it back. Try the solution that you find here, if it does not work the panel must be replaced.
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
The magnatron is shorting, overloading the high voltage
transformer. From the picture this looks like an older unit and
is probably not worth a magnatron replacement.
