They drained all the oil and refilled to recommended level, but now I have the evap light on, is this a result of the oil being over filled ?" error code is P0442 my mechanic reset it but the light is back, never had this problem before ! mechanic says the oil has nothing to do with this error code ! please help !
SOURCE: 1996 Chevy S10 4x4 - Dash lights need replacing
not easy, you have to remove bottom plastic from underneath the dash, there should be two or three you don't have to go to the passenger side, then the front contour snaps off bring your shifter arm al the way down to 1st gear and the steering colomn as well on that plastic contour you have the 4x4 switch to unplug, rear wiper switch, light switch, and rear hatch switch, wiggle the plastic out, now you should see the instrument cluster there should be two to 4 screws holding that in should be 7 mm screws, now careful, if you have the analog cluster you have the speedmeter cable in back to unclip, if digital odometer it's plugged in directly into the dash and there could be an additional plug on top of the cluster, if the cluster came out unclip the backing and you should see the back of the bulbs but careful some are twist off and many others are soudered on that board you aoto parts counter should have these lights in stock no sweat.... good luck
SOURCE: trying to locate evap valve on 2004 chevy s10
on the drivers side behind the gas tank under the truck bed.
SOURCE: '96 Chevy Monte Carlo- codes P0441 and P1655
it will be the evap solenoid that will be the problem,not sure where it is in that car, sorry
SOURCE: I have a 2006 Chevy Cobalt with the check engine
Did you get gas shortly before the light came on? It's not uncommon for a loose gas cap to set this code. Take the cap off and look at the seal. If it's cracked replace it with a new OEM cap. If not, reinstall it and make sure it's on all the way. Then you can clear the code and see if it comes back.
SOURCE: where is the oil sending unit located on a Chevy S10 Pickup.
MY S-10 IS LEAKING OIL. I WANT TO KNOW WHERE THE OIL SENDING UNIT IS.
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
