Whats the right way to hook up gas lines i took it apart and for got like a jerk my leaf blower is a ut-0846
SOURCE: Diesel fuel in homelite leaf blower !
this is not a problem
you need to remove all the fuel
and remove your spark plug add new fuel and with the spark plug out pull it over many times to purge the system now install a new spark plug and you will be fine
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
SOURCE: homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
