Viera TC-P50ST30 My TV is DOA. No power, sound, etc. No standby light. Confirmed house fuse, batteries, plus, etc. good. Tried unplugging for awhile. Makes a noise when I plug in to powerstrip or directly to wall. Someone said possible short. Pulled back cover. Checked ribbon between power supply and main board. Meter reads 5 when main not plugged into power. Drops to 2-3 when plugged to main. Is that where the short is? Isolated main by disconnecting all other connections to main. Should I just replace main or ? Thanks Sandra
Increase the volume on the TV and/or your connected media device (streaming player, Blu-ray player, cable or satellite box, etc.). Check the audio settings on your TV and connected devices. Turn off and unplug your TV and connected devices. Inspect the TV cables and ports, then check the ones on your devices as well.
Check Mute. Make sure the sound on your TV isn't muted. Push the Mute button on your TV remote. ...
Adjust Volume. On your TV remote, use the Volume Up/Down buttons. ...
Sound Menu. Push the Menu button on your TV Remote.
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
Fault to its main board. No start signal comes from it to power board to get it started. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Try to unplug the TV for about 20 minutes and then press and hold power button on the TV for about 10 seconds to reset your television and plug TV back in and see if that resolves the issue.If they problem still is showing up then the screen is broken and the back light is not working anymore and needs to be replaced.
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Unfortunately, your charter HD DVR cable box is not a Viera link device that is compatible with the TC-P50ST30. Viera Link only works to control Panasonic HDAVI devices that are Viera Link ready (and that use the same Viera link coding) when using the HDMI cable. Thus some Viera link devices of different generations will not work with the same Viera link remote.
www.shopjimmy.com is the place to get your parts. Beats buying a new TV
