I used to scan pics all the time, now all of a sudden after not using it as much the new pic I wanted to scan is all blurry. I have no idea why. Here's an example of the last image I scanned. https://twitter.com/SebMoji/status/296471028106919936 Now the images I try to scan I need to tweak the effects, but It makes the image look like a crappy webcam took a picture of it. The printer is a Canon Mx410. Thanks.
SOURCE: My scanner always scans with blurry lines across scanned images from it
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
SOURCE: HP Officejet Pro L7580
Refer to this link the will help you to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&lang=en&product=2512008
SOURCE: how to scan using canon pixma mp150
Acquire Text
The following instructions will give
you the basic instructions to acquire text from a scanned document in
Office Word 2007 using OmniPage SE.
I hoe it helps!!!
Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
The Options window will open.
The Options window will close and you'll return to Office Word 2007.
SOURCE: HP C5180 scanner won't scan an image
I'm running Windows Vista 64bit Ultimate Edition. Have the C5180, all-in-one. HP Solution Center continually closed, saying No HP Devices Found. I completely uninstalled the printer software, using the install utility. Then, using Add/Remove Programs, removed all of the other HP software on my PC. Then deleted the HP directory (in program files x86), and removed the HP registry key under software in both HKEY_LOCAL_MACHINE & HKEY_CURRENT_USER. Then rebooted. Once that was done and back up, I reran the install utility, but this time I followed the steps below (from here - http://hpanswers.blogspot.com/2007/12/no-hp-devices-detected-hp-solution.html):
Click on next until you get the below three options
(i) Recommended
(ii)Custom-------------->Select This
( iii)uninstall
Choose the custom install and click on next, ****
At begining of the installation, It gives you to 2 options
I) Yes, Check for updates..........
II) No, I prefer to do it Myself--Select this option and click on next
Immediatley in the next window ,you will have long list of softwares with the empty check boxes beside them.DO NOT select(check) Hp update, check rest of them and click on next to continue the installation.
You will able to open the HP solution centre with No errors.
Additionally, I did the following 2 steps, that I mostly found here (http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897551&lc=en&dlc=en&cc=us&softwareitem=oj-54112-1&os=2093&product=1153481&rule=9653&lang=en)
Add the following files to the Trusted programs list:
hpqkygrp.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqscnvw.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqste08.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqtra08.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqthb08.exe , located in the C:\program files\HP\digital imaging\bin directory.
Open the following ports on the firewall utility by following the instructions provided by the manufacturer:
UDP ports: 161, 427 and 137
TCP ports: 9220, 9500 and 9290
SOURCE: I have a Canon MX410
It's under printer options, format memory. You'll probably have to play with it a little because they like to hide the format option so you don't do it accidentally. Good luck! Please leave me a good rating, thanks! :)
