I have a kenmore front loading washer. I get a constant build uop of detergeant and mildew in and underneath the pullout compartment. I also get a fowl odor like the sewer when the washer is running. the washer is located on the second floor of my a house and the water line comes up two floors from the basement.
Can you see the washer drain line,or is it inside the wall.
You should never smell sewer, I would find a good plumber,or a handy man that knows plumbing, and have him open the wall (if needed)
and install p-trap where the washer is located, at about floor level.
From what you said I think that someone ran a straight line to the cellar and installed the p-trap down there, also have them check the line to see if the line has been connected to a breather line, if not have him install a breather line right there with a one way breather valve inside the wall. The buildup and mildew around the compartment is due to the way it was made by the MFG of the machine, most 1000.00 front washers have a very poor design with this. All you can do is to remove it and clean it with bleach once a month. If you live in an nice area,but not very rich, the cost to do the drain should be around or under 350.00. I hope you get this squared away with no problems.
Exterior
Wipe down the exterior of the washing machine with vinegar or your favorite all-purpose cleaner.
Tub
Pour two cups of vinegar or lemon juice into the tub, and run the washing machine through a complete cycle on the hottest setting to remove odors, stains and detergent build up.
Lid/Door
Scrub around the edge of the lid/door with vinegar to remove mildew and detergent build up.
Bleach and Fabric Softener Dispensers
Remove the bleach and fabric softener dispensers, and scrub them in the sink. Then, dry them thoroughly and return them to the machine.
