Troy Bilt 5.5hp Self Propelled Mower Logo
Posted on Mar 21, 2009
Troy Bilt Lawn Mower pull Cord broken
Pull cord to start the mower is broken. Need to replace the cord. Looking for instructions. Thx
  • 3 more comments
  • Anonymous Mar 15, 2014
    pull cord stuck
    troy bilt needs oil change
  • Anonymous Mar 16, 2014
    when the pull cord is pulled the engine fires but cuts out immediately
  • Anonymous Mar 17, 2014
    troy bilt 675 replace pull cord
  • Anonymous Mar 20, 2014
    Broken pull cord
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
4417
Points
10
There should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
1helpful
2answers
I bought a brand new Troy-bilt lawn mower model 336077 and tried to start it by pulling on the started string after filling gas and oil. But the cord is stuck and the mower does not start. WHat coul be the...
Are you holding the emergency stop lever? If you were operating the mower with your hands on the handle, there is a separate lever that you are expected to hold together with the main handle. You have to hold these two handles together to start and to operate the mower. Good luck.
3helpful
I have a Troy Bilt 675 lawn mower, won't start.
is the gas in the tank old? if so, try to drain it and put fresh gas in. Pull the spark plug to make sure it is not fouled and replace it or put in a new one. Check to make sure that you do not have the mixture or choke set to run too rich or too lean. If you are at an altitude above 2,500 feet you need to run more lean to compensate.
May 30, 2010 • Troy Garden
5helpful
2answers
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
1helpful
I have a TROY-BILT model 566 Smart Touch mulching mower. The starter pull cord (for lack of a better term) did not rewind when I tried to start the mower last weekend. I rewound the cord once by hand and...
sometimes these are shot dogs; these are what come and grap the engine and the cord is loose for about an inch or two and then you feel restance from the engine commpresion to start these DOGS are plastic and cheap
Apr 10, 2010 • Troy Garden
2answers
Broken pull cord. how do i get to the inside to fix it?
you need to take off the top cover. there are about 4 to 6 bolts to remove. the pull cord and winder will be under top cover
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
