My computer is locked and i forgot my password, i need to know how to change it or some how get into my computer.
SOURCE: forgot my password
If you have the install disk you can change the password from the install screen. insert disk, turn off computer, start up holding the "c" key, this will get you to the instal screen, from the menu at top , depending on os version, select either utilitys or password reset.
SOURCE: My Augen netbook needs a password. And I forgot
In some cases resetting certain passwords involves shorting out part of the motherboard; if not done correctly, you can fry it instead.
I have been working on PCs and compatible computers since 1985 and I still won't take that chance.
-a.
SOURCE: I am locked out of my netbook how do I get in when
i can help you i must know if it is definitely a acer one and what operating system are you using as my mother done this just last week and i was able to solve the problem straight away and that was with windows 7 and believe me the security is good.thanks i hope to hear from you soon
SOURCE: i have a netbook 7"
restart your netbook
when it begin open click f8
it will give you options
choose save mode then click enter
it will open as administrator
when it open
open run window
type "cmd"
click enter
will open dos
type net user
i will give you all users in your system,
chose your account name as example your computer name is lime
ok
then write it to reset password in this account
net user lime
then enter
restart your computer it will open without password
SOURCE: I locked my netbook an forgot my password what can i do?
Hi, Kind of hard to give a great answer here as there are three ways to add a password in a computer, one is in bios, as soon as computer come on, another is as an administrator in windows, or as a guest in windows. easiest is guest turn on computer and go to safe mode in windows go to password section because in safe mode you are administrator and can delete the guest password, as administrator in windows the easiest is to reload a fresh windows on your hard drive with the reload disks caution computers now load these on the hard drive and you should have made a set for use now, With Bios passwords there are unique ways for different brands and models , try typing in your model and asking for lost password removal in bios , using any search engine.
