Run the software calibration for easy diagnose, and fix it. However LUBE the deck belt with silicones or was. Read your owner manual, for to see what lubrication is your machine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Check for treadmill articles http://electro-medical.blogspot.com/
the drive belt is too loose. you need to tighten the belt that drives the front rolller, which drives the walking belt. depending on the type of treadmill there shoudl be a way you can do this by loosening the motor and adjusting that to tighten the belt. it could also be that the belt needs to be replaced and also could be the walking belt. you should try to tighten the walking belt first. that is at the end of the treadmill where you walk on it. there are two holes one on each side of the treadmill where teh belt goes back under the treadmill. there are allen key bolts that you need to tighten clockwise one turn then try the treadmill. if it doesnt tighten then turn another full turn. if not tight enough then it might be the drive belt. if you tighten the walking belt all the way then try to tighten the drive belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise 1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each edge of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Then, plug
in the power cord, insert the key, and walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off
the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
PROBLEM: The walking belt is off-center or slips when walked on
SOLUTION: a. If the walking belt has shifted to the left, first remove
Using the hex key, turn the left idler roller bolt clockwise
1/2 of a turn. Be careful not to overtighten the
walking belt. If the walking belt has shifted to the
right, turn the left idler roller bolt counterclockwise 1/2
of a turn. Then, plug in the power cord, insert the key,
and run the treadmill for a few minutes. Repeat until
the walking belt is centered.
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate www.twincityrepair.com
