Trying to disassemble one of handles to repair leak under handle. Water turned off ok & removed hex screw that I thought held handle base on (trying to lift straight up & off to get to replace seals)
So I believe based on what you are writing, it's a double handle style faucet. So you loosened the set screw that holds the handle on which is located near the top of the handle close to where you would grab. I would totally remove it from the handle just to make sure its not catching on a burr. If you have pulled and it will not come off, you will have to use a handle puller. Your local hardware store should carry them for less than $10. When you see the puller, it will be self explanatory on how to use it. Sometimes the handles can be hard to remove especially if they haven't been removed in a long time. Worst case is that you will have to cut the handle off and replace both the stem and the handle. That can be a little more costly. Hope this helps.
Delta Innovation bathroom sink set. There is no set screw in the handle, there is a hole where you'd think one would go, but there is nothing there!
