I have a oricom mic and a couple of wires have broken off there are 6 pins no1 is at 1oclock going round clock wise no6 is in the middle, the bare wire is on no5 could you tell me the rest, green black red blue white thanks
SOURCE: mic wiring
Check this link http://www.cbtricks.com/radios/rflimited/omegaforce_s45/index.htmand download the pdf file Owners manual page 8 has the info you need...Chia
SOURCE: connex 3300 mic wiring
I opened up one of my Cobra HighGear mics and here is how it is wired:
1. shield (Bare copper wires) --- twist them good and tin with a little solder
2. audio (White)
3. transmit (tx) (Red)
4. receive (rx) (Black)
Blue and Yellow are unused.
Dean
Rollin CBs
SOURCE: i have a general lee
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
6 pin socket
6 pin plug
7 pin
socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug
& socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin
round plug & socket
1 left hand turn - yellow
2 reverse -
black
3 earth -
white
4 right hand turn - green
6 stop - red
7 tail, clearance, side
markers - brown
round socket
large 5 pin round plug & socket
3 earth -
white
5 right hand turn -
green
6 stop - red
markers - brown
large 7 pin
round plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
7 pin round
heavy duty plug & socket
1 earth -
white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
5 right hand turn -
green
6 right hand rear , clearance and marker - brown
7 reverse/auxilary -
blue
7
pin flat plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
flat socket
12 pin flat
plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
8 battery supply -
orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
