There is no such thing as a reset button on your camera. If something oes wrong, or the camera acts strange, the only thing you can do is switch it of and after a few seconds switch it on again. This should be equal to a cold boot from a computer. This should solve all software releated problems. Sometimes yuo could go deeper, by also removing the battery and the memory card. and replacing them after a few moments. But if the problem keeps coming back, it will not be a software problem. Then you could look a bit deeper, like if the lens barrel is blocked, or contacts from battery and or memory card are dirty ot bent. If you can't find a thing, please contact a Nikon Certified service centre.
ViewNX won't download pictures from your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program. You can download the current version of all (free) Nikon software here.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
You can download all (free) Nikon software from http://support.nikontech.com/app/answers/detail/a_id/61
