Large sweep second hand on my new citizen chronograph mod no.ca0258-03e only goes round when i press the upper button to start the 1hr chronograph,after 1hr the large sweep hand stops,is this normal? does not say in manual.
On your particular model the seconds hand is the small dial at 6 o'clock and if you look at this you should see this moving around constantly. The larger hand you may think is the second hand is actually your Chrono hand and will only go around when using the stopwatch etc.
Yours
Cole Wardle
After Sales Service Administrator
Citizen Watch United Kingdom, Ltd.
SUPPLIER OF THE YEAR: UK JEWELLERY AWARDS 2014
MARKETING CAMPAIGN OF THE YEAR: UK JEWELLERY AWARDS 2014
T: +44 (0)118 936 8853 (direct)
+44 (0)118 989 0333 (switchboard)
F: +44 (0)118 989 0536
M: [email protected]
W: www.citizenwatch.co.uk
Any views or opinions are solely those of the author and do not necessarily represent those of Citizen Watch United Kingdom, Ltd. This email is private and may be confidential and is for the intended recipient only. If misdirected, please notify Citizen Watch United Kingdom, Ltd. by telephone and confirm that it has been deleted from your system and any copies destroyed. If you are not the intended recipient you are strictly prohibited from using, printing, copying, distributing or disseminating this e-mail or any information contained in it. We use reasonable endeavours to virus scan all e-mails leaving the company but no warranty is given that this email and any attachments are virus free. You should undertake your own virus checking. The right to monitor e-mail communications through our networks is reserved by us.
SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
