1997 Toyota 4Runner Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1997 4Runner oil quantity
We are changing the oil and filter in a 1997 toyota 4Runner, V6, 3 liter engine.
We do not have an owners manual.
What quantity of oil do we need to add?
landon burnett
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 07, 2013
landon burnett
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1829
Points
6
My 1994 4runner takes 5 quarts even
Anonymous
Level 3:
President:
  • Master 2,004 Answers
  • Posted on Mar 21, 2009
Anonymous
Master
Level 3:
President:
Answers
2004
Questions
Helped
702394
Points
7857
For a V6 # Liter engine, you will use a galon and almost half (that is about 6 Liters of oil). I use a Toyota camry V6 3 Liter engine that shares the same engine with the Toyota 4Runner.
Rate this Fixya!
  • Anonymous Aug 29, 2011
    not necessarily, it depends on the liter, my 3.0 L takes 4.5 quarts of oil
What is the oil capacity for Hino dutro SO5D? what is the
The oil capacity for a Hino Dutro with the SO5D engine can vary slightly depending on the exact model and year. However, as a general guideline, the engine oil capacity for the Hino Dutro SO5D engine is approximately 8 to 9 liters (about 2.1 to 2.4 gallons) of engine oil when equipped with an oil filter change.
Please note that it's always a good practice to consult your vehicle's owner's manual or service manual for the most accurate and specific information regarding oil capacity and maintenance intervals for your particular model and year. This will ensure that you use the correct oil type and quantity for your vehicle.
1helpful
2answers
7helpful
2answers
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
3answers
What kinda oil do i use
3.1 liter engine Use 5W30
Capacity is 4.3 liters with oil filter changed.
3.4 liter engine Use 5W30
Capacity is 5.2 liters with oil filter changed.
Good luck and how this helps.
2answers
Trying to find out how much oil the Triton V-10 takes when I do my oil change? I cant seem to find it or anyone who knows
It should be listed in the owners manual, but because of different oil cooler setups you may have to do the change yourself and add oil until the correct level is established..... for the first oil change.
Most likely 7 liters,but start with 5,run the engine to fill the oil filter,let it sit for 5 mins and recheck and fill to full.
Note the amount needed for next time.
4helpful
2answers
2005 toyota corolla motor oil capacity?
if you have a 1ZZ engine
4.2 quarts, 4.4 quarts with oil filter change
if you have the 2ZZ engine (XRS model) it is
4.4 quarts, 4.6 quarts with oil filter change
NOTE these are updated capacities that reflect changes identified in TSB: TSB-0134-08 issued July 15, 2008.
Your owners manual will reflect a lesser quantity that Toyota has since revised.
1helpful
2answers
Quantity of Oil to use
most only take 5 qt put in 4 and check the dip stick if it is on full run the engine for a min and let it stand for a bit recheck and add what you need to full mark
3answers
Quantity of engine oil used in 1 HD engine toyota land cruiser
The Landcruiser 1HD engine uses 9.3 liters of oil with the filter. The oil is replaced every 5000Kms.
2answers
ATF Quantity - Toyota Prado 1997 VX
owners manual, dealership parts/ service
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
