A
Anonymous Posted on Jun 02, 2013
SANSUI Model HTS-17Z
Having a problem with the volume of the system. Max volume is just audible, but would like to play music much louder.
  • Kavenoo brave May 21, 2019
    how can I connect my sansui model HTS 17z to a jebson 3003ES
1 Related Answer
Anonymous
  • 1284 Answers
  • Posted on Mar 24, 2009
SOURCE: Audio humm on VIZIO VW32LHDT30A
You have a bad ground through the cable box or cable system. This causes AC to leak into the TV showing up as bars that roll from bottom to top and sometimes audible as well. Have the cable company replace the cable box and/or check out for proper grounding outside at the demarcation point.
tip
Adjusting your gain for your amplifier, or amplifiers
I contacted JBL, and Pioneer about the RCA outputs of the DEH-P5800MP. I got a question answered by JBL that you should gain your amplifier, or amplifiers at half of the Head Units volume, in which case the 5800 model has a max volume of 62. I would assume that this goes for any unit since I didn't give JBL the model or brand, which indicates that they are giving a tip on every, or most units unless specified. You can e-mail the manufacture on what unit you have just in case yours is different. I found after a good conversation with the technical support guy at Pioneer that you should turn your volume up to 25-30 (25 for your loudest CD, and gain it from there. I told him that I was an audiophile and he suggested that I could gain it at 45 for my lowest recorded CD. I have been installing and gaining systems at 3/4 volume, or if the max volume was 62 then I would gain my lowest recorded digital CD at that volume. I was amazed that JBL had an answer for probably 90% of the head units, and I have learned something new. I was under the assumption that the higher the volume the more voltage the RCA's put out allowing you to be able to have your amp gain at a lower level. From my experience of 12 years, hearing both companies say roughly the same thing it is apparent that Pioneer units with a 2 volt output should be gained at the 25-30 volume range(probably for your lowest recorded CD. I have CD's that are pure digital and bass CD's and CD's that are recorded louder (like techno music, or alternative music) If you know what you are doing, and can hear distortion, like I can, the tech said that I could gain it at 45 for the lowest recorded CD. This allows your lowest recorded CD to be played at max volume at 30-45, and your loudest CD's would be at peak volume before 30, or 45 if you choose that route. Keep in mind that less power blows speakers before more power does. That is the best advice I can give, and I will adjust my system accordingly to there recommendations. Thank you
Arcing sound
laouli,
check the program you are using to play the sound if the volume is at an audible level, next check your *Master Volume* settings bottom right corner on the desktop *windows*. if this does not work you need the correct audio driver,
please advise your Operating system (windows or Mac)
Version *64 or 32* bit.
Make and Model of the Laptop
Volume keyboard
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
1helpful
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
THE VOLUME, USING THE REMOTE AND THE TV, DOES NOT GO ABOVE 50%. THIS IS NOT LOUD ENOUGH FOR THE OWNER WHO IS HARD OF HEARING. IS THERE A WAY TO INCREASE THE VOLUME. IT IS A SANSUI MODEL #LCDCD1909.
well if the volume wont go any louder on the tv even without the remote that can be a problem what i would recommend to do is get a stereo that you could hook up to the cable or satellite or if you use digital antenna use the output of a vcr to plug into a stereo system then you can use a stereo to increase the volume.
2answers
Can the audible volume be turned up louder on a
I think the only solution for you my friend will be too invest in a headset of some kind which should plug into your unit which will help you to hear better.
1helpful
VOLUME NOT LOUD ENOUGH
If you would be willing to modify your phone slightly (software tweaks) this guys has an app that will help:http://montecristoff.webs.com/index.htm
There is simply a sound limit in the software that stops it from going louder.
1helpful
Bose cinemate acoustimass module
try taking ones apart that have the rumbling and see if theres anything loose inside
 Grubhead
Grubhead
SmartAviator
SmartAviator
