Kenmore dishwasher ultrawash quiet guard standard--no idea what the model number is, I'm a renter.
Regarding the soap dispenser with the lid that latches closed and opens at some point in the wash cycle....the 2-inch long plastic piece that kept the lid shut came off/out of its slot so now the lid can not be shut. How can I fix this? There must have been a spring or something inside the slot that controlled the plastic locking piece.
Thanks...
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
SOURCE: Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
SOURCE: Soap dispenser will not open in dishwasher
depending on the model and make of the dishwasher you're going to have to determine if it the control which actiavtes the soleinod of the wax motor that springs the dispenser door open and later in the cycle it also dipenseces the rinse aid
SOURCE: Latch cover on dishwasher soap dispenser no longer functions.
hello there. i hope i can help you?. please check the latch spray a little wd40. and give the soap dispenser. a good clean with warm water. please check that you are useing the correct soap? as this can cause alot of problems. check once a week.top tip give the machine a good clean once a month. i hope this has helped you marymena? also please check for any little obstructions.
SOURCE: The soap dispenser on our Kenmore Elite dishwasher
Yes its probably the little latch that holds the door closed thats worn out.
Hi Hulo - Sounds like the dispenser detergent drawer latch may possibly be damaged or broken. Consult a professional to accurately diagnosis the unit and assist with the repairs.
There
are three common problems that cause the Soap Dispenser or Cup not to
open. I have a tip that will explain these problems in
detail....
Dishwasher Repair Problem Detergent
Cup does not Open
heatman101
