Subaru 1992 Legacy/Outback Condenser Logo
Joseph Baxter Posted on Jun 02, 2013
A/C not working, just blowing hot air.
I turn on the A/C and all I get is warm air. The clutch isn't engaging. How do I fix the problem and what kind of prices am I looking at? I thought mybe that it just needed to be charged so I added a half a can of coolant to it.
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 22 Answers
  • Posted on Jun 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
22
Questions
0
Helped
12224
Points
42
It has a leak somewhere. You need some stop leak and it'll take more than 1/2can of refrigerant to engage clutch due to low pressure switch
1helpful
Arcondition blows hot air, freon in the blue and clutch on compressor engage
Make sure your blend door is closing all the way and that the actuator actually works.
2000 saturn,is blowing hot air even after I charged it and the ac coompres
I would make sure the shut off valve between the cold air and warm air is engaging. this is controlled by a vacume
My air conditioner is blowing warm air on the driver side and cold on the passenger side
see this steps and think with clearly and logically NOT feared. God bless you
checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
If my compressor wheel isn't spinning how do I know if it is the compressor or the ac clutch? System is charged but ac is blowing hot air
The question is: why isn't the compressor clutch turning
The compressor isn't likely seized,it may leak refrigerant,
but won't be what your asking.
The clutch can be jumped to test that
If okey, then you have to diagnose the entire
A/C Electrical System
How do you know it is properly charged,you put
refrigerant gauges on the system?
My 1996 Lexus ES300 ac blows cold for a while then starts blowing warm air. Then I turn it off for a while
There are a number of possibilities.
1. If the compressor has a clutch, do you hear it engaging and disengaging?
2. The valve controlling the hot water going to the heater which mixes warm air with the cold air from the evaporator, is not working properly so it si not maintaining proper temperature.
3. THe temperature sensor that senses air temp at the intake to the AC in the cabin is defective.
4. THis is too comlicated to fix yourself, so you need to take it to an AC expert who knows this particular model.
I have 2000 ES300
1helpful
Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
HY MY NAME IS DUANE AND I NEED HELP FIGUREING OUT WHY MY AC WORKS GREAT IT'S BLOWS ICE COLD AND SOMETIMES IT BLOWS HOT IT JUST STARTED A FEW DAYS AGO WHAT DO THINK IT MIGHT BE? THAKS YOU
it may be that the clutch on the A/C compressor is faulty & sometimes it doesn't engage or it could be a wire is loose or a loose connector plug, next time it blows hot air when it should be cold lift the hood & make sure that the clutch on the A/C is engaged ......hope this helps......cheers.
My a/c is not working properly. It seems like every few months it stops blowing cold air and for about 2 weeks it blows hot air only.
That could be a variety of problems. The first thing you might do is this. When it isn't working, open the hood and see if the clutch on the A/C compressor is cycling. If it engages and disengages while the air conditioning is on, that would indicate that the problem might be ducting or another issue. If the clutch doesn't cycle, one of the first things I would check would be to see if there was power to the clutch when the A/C is turned on. It would be helpful to know what your vehicle is, such as year, model, and if it's equipped with Automatic Climate Control like many Buicks are.
Problem with heating and air conditioning. The driver's side is blowing hot air and the passenger side is blowing cold air
Air Conditioner blows warm air
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
3helpful
A/c stopped working,the clutch still engages, fan blows warm, found no fluid leaks
the air blend door inside the heating / cooling unit that sits under the dash is probably not moving. there is an electric motor and control unit that moves the air blend door (assuming you have the electric dial or push button digital controls. some of these vehicles have a valve that shuts off the antifreeze from cycling through the heater and if it remains open then you would get "not hot" but just warm air.
Top Subaru Heating & Cooling Experts
Paul Carew
john h
Are you a Subaru Heating and Cooling Expert? Answer questions, earn points and help others
