Hi. My mum has a new DGM T909. She did a system restore and now the screen is stuck with "boot into recovery mode". Ive tried several things and none have seemed to work. Thanks
SOURCE: Zen microphoto stuck on recovery mode
make sure you have media player 11
try another computer or laptop till it does find the player and upgrade the firmware
SOURCE: d2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
SOURCE: Creative Zen Touch stuck in "recovery mode"
maybe you can find help through this tool: http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
Hold player in one hand and bang it on your other hand. This worked for me when I was unable to reload firmware.
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reboot" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo!
You have your Zen as new and should not have problem. Good luck!
