Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
Anonymous Posted on Jun 02, 2013
Why is motor not running now?
I just replaced #1 head and valves. ran pefect for 6 hours then was backfiring while running. now you turn key and it only clicks with partial turnover
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Kohler Expert 573 Answers
  • Posted on Nov 22, 2013
Renee F
Kohler Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248134
Points
680
It sounds like you made a bad valve adjustment and it has thrown a rod, and binding on one cylinder, hence partial turnover, cylinder on compression. Pull apart again and re-check.
P0303 intake backfire
problem with no3 cylinder hydraulic lifter
pumping up and holding the valve off the seat
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Tractor ran fine 1 week ago. did not run over anything. several attempt to start yield only backfires. plug removal, air cleaner removal, and blowing out cylinder and carb did not prevent backfires. I...
If you are talking about a lawn tractor with a briggs and stratton or Kawasaki engine you have over head valves that has not been adjusted and push rob may have fallen out or is to tight. Owners manuals will not tell customers this info all the time. I have been servicing all makes and models of small engines for over 19 years. Works at several dealers. And do it on my own now so i can help customers without charging arm and leg.
1helpful
I have a 2454yth with a brigg and staton motor. I have fire in both cylinders. 140 lbs compression in both. It backfires out the carb and will not run. when it ran last, it ran on 1 cylinder only. Any...
there is a chance that the key in the flywheel has been sheared, this will cause them to backfire , pull flywheel and check that key is ok .if its ok .. than i would say there is a coil problem.. ? check to see if oil smells like gas ? and all safety (kills) are un hooked. jay
Starter motor can't turn engine through compression stroke
valves are out of adjustment. reset them and it will do fine.
5helpful
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
5helpful
3answers
1997 chevy cheyenne c2500...i get a popping noise when i press the accelerator...help meeeeee please...197,000miles i frustrated
Does it idle smooth or rough? Steady loping miss at idle? Loses power as rpm's increase? I'm a shadetree mechanic, and even though your engine is a vortec, it still uses these parts, so you may find this useful.
Make sure your plug wires are good, start it after dark, raise the hood, in darkness you should see tiny sparks jumping from the wires if they are bad.
Most likely cause of my intake backfiring was #5 & #7 plug wires switched. Bad plug wires can also short onto each other and cause the wrong cylinder to fire while it's intake valve is still open, igniting back into the intake. 350 chevy firing order is 18436572. #5 & #7 are on the driver side, the closest to the back. #7 fires right after #5, by switching them I had caused #5 to fire too late / #7 too early hitting the accelerator causes the spark timing to advance, firing #7 while the intake valve was still closing, sending flame up into the raw fuel charged intake, causing the explosion or POP under the hood. The symptom I had was rough idle, stumbling / popping on acceleration, which got much worse as it warmed up.
OTHER PROBLEMS TO LOOK AT:
replace fuel filter, and have a mechanic check the fuel pressure. He can tell you whether the pressure regulator or the fuel pump is bad. Low fuel pressure will lead to engine damage as you'll see below. It causes the combustion gases to run too hot, warping valves.
I have a 95 c2500 with 350 Throttle body injection(not vortec), the problem I had was multiple. The timing chain was extremely worn out, causing erratic timing. The fuel pump was bad( causing loss of power as rpm increased)( letting that continue for 6 mos caused several intake and exhaust valves to overheat, warp and burn). The Throttle position sensor was bad, causing transmission shifting / slamming at odd rpms, and possibly contributing to the popping(backfiring up through the intake). The temp sensor on the intake was bad(cold temp fuel mixture control), and the oxygen sensor on the exhaust pipe had the wires pulled out of it(warm temp fuel mixture control). The spark control module also was bad(causes misfires). Later I also had 2 spark plug wires that were on the wrong plugs(the main cause of the intake backfiring). It is an old work truck, 190,000 miles, many parts/gallons of sweat later, now it runs strong. These motors are worth repairing, as long as the oil-pressure is good and the compression is still decent. I've had 3 vehicles before this one, same motor, great mileage, power and reliability. I've heard the vortecs are even better, as long as the oil gets changed regularly.
Start cheap. Try each item, if that is not it, go to the next( or spend a hundred or so on a full diagnostic by a well established mechanic(not a tire installer who just started his ASE studies. good engine diagnosis requires years of experience and teardowns to be able to determine the causes while running) :
1.) While engine is running in park, use plastic pliers(shock protection, be careful!!!) to remove and reconnect a plug wire at the coil. Listen for a change in the idle speed and smoothness. Move to the next if you hear a change, this means that that plug and wire are working properly(disconnecting them causes the motor to idle up, run rougher). If unplugging them doesn't cause a change: That wire or plug is likely bad. take both to an autoparts store to be tested. Replace the problem part, if that does not fix a miss, see #2 below.
2.) Do a cylinder compression test, to see if you have any valve issues. I bought a $40 compression tester kit. It takes about an hour, but it will tell you alot about the engines health. Mine had a range of 140-170 psi, except for #1( 0 psi, cracked and torched valve) and #7(120 psi, warped valve), I had to pull the intake and that head off for replacement valves(got lucky, cast iron head was not warped)
3.)pull, test(a mechanic can do this) and if necessary replace the throttle position sensor($23 part on tbi motors). This tells the computer how much gas pedal you are using. If it is bad, you fuel mixture will be erratic and can cause misfires, and your transmission may be shifting weird / hard.
4.) Replace the spark plugs with original AC Delco, use good wires, cap and rotor. Cheaper parts can have too much resitance to electric flow, causing poor running. I switched from autolite platinums--> to Delco = huge difference.
5.) If the timing chain is original. It is time, trust me. Mine had so much slop, I was amazed it had not jumped a tooth. This will cause poor power / erratic idle / possible backfiring if really advancing / retarding ignition. Unless you are a mechanic, this is not recommended for do it yourself. The upper radiator housing, fan, waterpump, timing cover and oil-pan have to be dropped and regasketed afterwards. Hours of fun.
my truck sequence of events:
Bought spring '08, noticed poor power / slight miss, replaced plugs wires cap rotor, repaired rear brake line rust-out, new tires, mechanic replaced fuel filter, advised fuel pump was not putting out enough pressure, tried ignoring and drove till fall--> developed REALLY severe miss( no intake backfiring), barely made it home.
Starting this spring: Compression test --> valve issues, removed all front engine components(alt, P.S.(pressed on pulley will need a puller kit to remove)), intake manifold and driverside cylinderhead(found a hole in #1 exhaust valve big enough to slide pencil through), had 4 valves replaced at machine shop, reassembled engine, dropped gastank, replaced fuelpump assembly and fuel-lines(rusted), replaced oxy sensor on exhaust manifold, started motor and set timing(while computer timing wire was disconnected under dashboard), ran rough / intake backfiring upon any acceleration, erratic timing, replaced timing chain = steady timing, still ran rough/backfire though, replaced temp sensor(no change), tested barometric pressure module = ok, replaced distributor(unnecessary), replaced throttle position sensor = ran a little better/still backfiring/ transmission problem fixed too, ran resistance check on wires with ohmmeter-->found #5 & #7 plug wires were switched, fixed that, ran great, replaced exaust system behind the converter, sounds great / runs great / lesson learned. If a mechanic advises a repair, get a second opinion... but don't ignore it, it creates bigger problems, like torched valves.
Good luck.
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
1helpful
Motor was running smooth new cambelt service ect,adjusted timming because could hear pinning on accelaration switched car off for one hour, while looking for an electrical fault on aircon turned aircon...
if you turned the motor backwards and then tried to start belt could have jumped this is a interferance motor which means the valves overlap the pistons ! you could have bent the valves.take it back to the person who did your timing belt
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
