Minolta magicolor 2200 DeskLaser Printer Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magicolor 2200 error Service Call 1f fuser low therm
What does this mean? We just replaced the transfer belt (cost $365), and then got this additional error message.
Thanks in advance for any help you can offer.
David Burkhart
Level 2:
  • Expert 210 Answers
  • Posted on Sep 01, 2009
David Burkhart
Expert
Level 2:
Answers
210
Questions
6
Helped
139493
Points
329
There are two small thermsstats, called "snap-action disc thermostats" that control the electricity flow to the fuser lamps. One of these has likely gone bad.
As an explanation, these thermostats work just like the thermostat for a typical home central heating system. They keep the fuser temperature between 130 and 150 degrees by turning the fuser lamps (the parts that heat up the fuser) on and off. They do this by allowing electricity to flow to the fuser lamps until the temperature of either thermostat reaches 150 degrees. At 150 degrees, either thermostat will turn off electricity to the fuser lamps, allowing the temperature to cool back down to about 130 degrees. Once the temperature returns to 130 degrees, it allows the electricity to flow again to repeat the process.
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
1helpful
My Magicolor 2200 ghosts in color and in black. Ghosting appear about 1/2 way down an letter size sheet. Installing new fuser has no effect.
This is a symptom of a well-used transfer belt. Replacing it should do the trick.
To verify: Check the transfer belt. The transfer belt is the large replaceable unit close to the center of the printer. It should have excess toner clinging to it. Don't bother trying to clean it off. It will just return the next time you print.
I'm currently looking for a way to squeeze a little more life out of it. But, am having no luck so far.
2helpful
Magicolor 2200 DL - replace transfer belt
Is this an error 16 rorate problem? It does seem weird that you still get it having replaced the transfer unit.
However the printer does have a nasty habit of not re-setting things correctly - it creates the error message by blowing a fuse on the unit and it has been known to do this even when a new unit is put in.
There are a couple of places on ebay that sell a kit that explains how to get to the fuse and they supply a new fuse. It appears to be a 1/4 amp slow blow fuse
To get at it you will need to unscrew a black plastic plate at one end of the transfer unit (it is the one that has a square hole with the main electrical contacts poking through. Loosen the 2 screws and remove. the fuse is on a small circuit board that is easily removed. replace teh fuse (needs soldering) and this might do the trick. If you have a tester might be worth removing the small circuit board (wire connector comes off easily) and checking.
This fues usually blows when the transfer unit is old and a sensor unit gets clogged up. However even when teh sensor and the band at the side of the belt has been cleaned the fuse still sometimes blows.
This might solve the problem.
1helpful
Get message of fuser low therm 1F
One of the two small thermostats, that are called "snap-action disc thermostats" and control the electricity flow to the fuser lamps, has likely gone bad. If you are feeling generous to the money pit governed by Konica-Minolta, you'll need to replace the fuser unit. Otherwise, you'll probably need to locate and replace the bad thermostat. If you are not electronics saavy, I recommend taking the fuser unit to an electronics shop and asking them to check for and replace any bad thermostats.
As an explanation, these thermostats work just like the thermostat for a typical home central heating system. While in use, they keep the fuser temperature between 130 and 150 degrees by turning the fuser lamps (the parts that heat up the fuser) on and off. They do this by allowing electricity to flow to the fuser lamps until the temperature of either thermostat reaches 150 degrees. Once that happens, the thermostat will turn off electricity to the fuser lamps, allowing the temperature to cool back down to about 130 degrees. Once the temperature returns to 130 degrees, it allows the electricity to flow again to repeat the process.
1helpful
2answers
Service call 08 main motor
Got answer from fixyourownprinter.com. " Service call 08 main motor" means the main motor is not functioning. Could be the fuser siezed up preventing the motor from turning.
Are you there? I have a problem with a Minolta 2200 as to the error about replace the transfer belt . Can you help
contact minolta tech support coz they will tell you how to change the transfer belt if you do not know any thing about printers get profeshinal help
"service call 08 main motor"
Might check the fuser unit and replace it, Main motor can not turn something is preventing that warm up mean fuser issue
Magicolor 2200 can't complete warm-up
clean the connectors of the toner cartridge, transfer unit, drum cartridge. did it signal ** toner? replace if needed. check the status of your printer install the printer utility then see the machine status you will see error codes. tell me if what is the code..
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
