Garmin 185 Sounder GPS Receiver Logo
Posted on Mar 21, 2009
Remove and replace the lithium coin batt from a Garmin gpsmap185
My memory battery for my Garmin GPSMAP185 needs to be replaced. It is welded to to circuit board. I would like to know how to remove and reinstall the new one without damaging the computer or new battery.
  • 1 more comment
  • Skuta May 08, 2009
    Same problem, any solutions?
  • Anonymous May 12, 2009
    same thing here. any idea?
    samma
  • bk44194 May 15, 2009
    I also need to replace the memory battery in my Garmin GPSMAP 185 Sounder any suggestions. Where can I purchase one of those batteries with the welded terminal leads.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
967
Points
The battery is a Panasonic BR2032-1F2; the suffix desinates that it has two flat tabs for soldering into the unit horizontally. Once you remove tha back of the unit, you'll see the battery next to a resistor that's siliconed in place. You'll need to knife the silicone loose so you can gently move the resistor aside to reach the soldered tab underneath it. Just heat the solder on each tab with a small soldering iron until it melts and the tab pops loose.
Install the new battery with the unmarked side up (the other side has type) and solder in place. Reinstall the power and antenna connections in the cover, replace the cover, power up the unit and start re-creating all your lost waypoints.
Batteries can be ordered online from Allied Electronics at $2.42ea (www.alliedelec.com)
blackcatjim
Anonymous
Level 1:
  • Posted on Jun 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
967
Points
OK called Garmin and they no longer support this machine so we are on our own. The good part is the battery is a run of the mill 2032 battery with nothing more than a tab welded to it to make connections easier. The battery is used to keep your way points and tracks in memory. Your machine will work even if the battery dies but your way points will not be held in memory. You will loose them when the battery dies or when you change the battery. If you have PC link , back up first.
Unscrew back cover, you will see battery, unsolder using least heat possible, put in new battery and use small wire to make link from back of battery to the original connection point...when you reseal the case make sure to wipe the seal and mating surfaces clean and assemble carefully. Tighten screws evenly a little on each one at a time until you feel it is snug. Tighter is not necessarily better so do not over tighten.
Hope this helps---p.s. batteries are same kind used in just about every computer out there---there are good ones and bad ones spend the extra 2 bucks and get a Duracel ---or you will be doing this again in a year or two..
  • Anonymous Jun 02, 2009
    Just an update---the battery is an BR2032 I used a DL 2032. Odd thing is the connections went fine, lost my saved data as expected but on restart unit still says memory battery low....
    What Garmin rep did not say was that both sides of battery have a soldered connection and the battery is in upside down There is also a ring of insulating material around the battery ( I used silcone) to prevent a short to the posts you solder to. I have rechecked the battery and it is good, I obviously have a connection as it will save data again even after disconnected from the main power and reconnected ( not sure if htis maters) but it still gives Low memory battery error at start. I am wondering if there is a reset for this error or something as unit works fine now and I know I have voltage. Without battery the unit will not save any data. Tried it.
    Good luck guys..PS if your over 40 you will need your glasses for the soldering lol:-)
How do i change a battery in a garmin 305
Hi David!
From your Owners Manual (Page 54)
http://www8.garmin.com/manuals/984_OwnersManual.pdf
REPLACE THE HEART RATE MONITOR BATTERY
"The heart rate monitor contains a user replaceable CR 2032 battery...
Locate the circular battery cover on the back of the heart rate monitor. Use a coin to twist the cover counter-clockwise until it is loose enough to remove. Remove the cover and replace the battery. Be careful not to lose or damage the o-ring gasket on the cover. Then use a coin to twist the cover back into place."
Hope this helps.
5helpful
I have a Cannon EOS 30D. There is no response whatsoever when the power switch is turned on. I have tried 2 separate fully charged batteries with no change in the problem. Can you help me? ...
There is a small Lithium coin battery on the side of the battery compartment that is the memory battery for the camera functions. Remove the battery pack first, then holding the camera with the lens facing your body look at the top back ledge of the battery compartment and see lettering CR2016. slide your finger down the back ledge and feel the ridges. with slight pressure slide the compartment up and take out the CR lithium coin battery. replace with a like new battery. If you ever need to reset a stuck program in the camera, remove this battery for a few minutes and the camera will re-boot to factory settings. This battery last for about 5 years.
8helpful
Replacing memory battery garmin gps 75
The battery inside is a panasonic 3v Panasonic
Battery, Lithium, 3v, 190ma, Coin
cell
884-0301 BR2032
You need a clip too
Keystone Electronics
Battery Holder, Coin-Cell; 20
mm; 0.896 in.; Glass Filled
Nylon; 1; 1 AWG
Remove battery pack. Open unit by the six small screws in the back. The coin battery is in the bottom right (mine had a blue cover) The original ones are soldered/pressed in. Replace with the holder and rewire. Cheers
Kodak 8.2 will not turn on i've only had the camera for a couple of months . I have charges the camera for a day or two and it still will not come on
I think you mean the camera and not the ESS software. Since you have only noted the kond of the software and not the model of the camera I have written 2 possible solutions for you:
I hope this will help:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
1helpful
Camera will not charge or turn on although battery is fine.
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
Contact KODAK:
Oct 13, 2009 • Cameras
Our EasyShare CX7530 will come on and then go right back off. You can not take pictures.
Make sure that you are installing a fresh/ full charged battery
AA non-rechargeable lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If problem still persist call the Tech Number
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
The lens of my kodak easyshare is not working when i turned it on....
Here are the steps:
Contact KODAK:
Here are the steps:
Contact KODAK:
Garmin chart plotter not booting up.
Hi again,
Appreciate the update. Incidentally, most batteries for this purpose are Lithium 3 volts, coin size. Often, battery removal also performs a reset if not replaced immediately.
Though my money is really on the firmware.
Cheers.
GPS 48 MEMORY LOSE
You can go to batteries plus or wherever and buy a new 3 volt battery for it. You will have to unsoder the old one and soder the new one back in. Original was a VL1220, I replaced with a Dantona Lith 1-2VLS
http://shop.industrialpartner.com/D/dantona/lith-1-2vls.htm
http://www.fedcobattery.com/b.cfm/all-vendor/lithium-coin/Rechargeable-Lithium-Coin-Cell-for-Printed-Circuit-Mount_VL1220-1VC.htm
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
